In cab noise level
In cab noise level
So I am on a many quests with my rig..
and one of them is to bring down the in cab noise while driving..
On my treck to drop off the kid and to work.. I have been measuring 87db, with my phone. It may not be accurate but I hope its its precise.
Rig Specs
84 4runner
Home Depot Sound deadening
Carpet pad in the back over OEM carpet
LCE headers
Most of the Stock intake system with a battery swap
I also have a gap in on the passenger side door by the B-pillar side.
Any thoughts..or recomendations..
I am thinking of lining the inside of the Hood
Also kinda want to put in Hood louvers to keep the fan from coming on as often.
Rig Specs
84 4runner
LCE headers
I used Dynamat, and its generic equivalent, on the inside of my doors, roof, floorboard, and back wall of the cab on my pick up and it made a huge difference. You can find good deals on the generic brand on ebay.
Can you see light through the gap in the door? Sounds like it needs new weather striping.
I installed UltaTouch radiant barrier by Bondedlogic sold at HomeDepot.
Very happy with my results in my DD 10k miles later.
Here are photos of my install in my 1985 XtraCab.
https://www.yotatech.com/g/album/2882294
I have used some stuff similar to what you mention but found the Dynamat to be far superior. The thick rubber/tar material also keeps the metal from vibrating which makes more noise than you think. I also noticed after covering my doors that they sound extremely solid when I shut them compared to before treatment. A friend that owns an audio shop turned me on to the material. He uses it in all his competition cars.
Doing the rear panels with Peel and Seal I can talk to the kids without yelling for them to hear. I also do the doors and floor board. On the door gap, is the hinges sitting level on the door frame? I know you flopped it over. A little bulge will cause the door not to sit tight. It doesnt take much. I would compare each side and look for any metal stress or paint flaking.
I believe this is the brand I have used in the past.
http://www.ebay.com/itm/84-88-Toyota-4Runner-Pickup-Truck-Rubber-Door-Weatherstrip-Seals-Pair-Set-/130894580598?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1986%7CMake%3AToyota%7CModel%3A4Runner&hash=item1e79eccb76&vxp=mtr&rmvSB=true
I just use Ear Plugs it was the easy option .Most often when I need to drive something not quite finished.
Works great when traveling more then 10 miles with wives and girl friends or boy friends depending which you prefer.
I just turn up my 8 Track player and listen to Dean Martin
I never had a PING sound. My door however did have a hollow echo type sound whenever I shut it.
And I put the dynamat on the inside of the door skin not the part the door panel attaches to.
Jeffreynmandy
Jul 18, 2015 08:26 AM
mengquis
Jul 13, 2015 10:39 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
