Brake problem!!!!! Help
Old Jan 10, 2009 | 07:03 AM
yota lover's Avatar
I am driving home from school and i notice that it is harder to stop than usual. When i get home i look at my front brakes and they are smoking. So i though it would be an easy fix just change brake pads and rotors... of chorus everything has to be difficult this proves nearly impossible. Does anyonehave any suggestions on how to get the cone washers out of the free wheeling hubs?
Old Jan 10, 2009 | 07:26 AM
bigt's Avatar
ok use a torch heat them up and tap the side with a hammer and they will fly out in no time!sounds like a seized caliper~!
Old Jan 10, 2009 | 07:36 AM
4Crawler's Avatar
This is how I remove mine:
- http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
Old Jan 10, 2009 | 08:34 AM
GSGALLANT's Avatar
place a brass drift (use brass because it's softer that the stud material) on the end of one of the studs, and give a quick tap to the end of the drift with a small mallet. A couple of hits should pop the cone washers right out. Be careful... sometimes they blast out of there pretty quick.
Old Jan 10, 2009 | 09:38 AM
yota lover's Avatar
I forgot to mention that when we looked at the brake pads there was plenty left on them at least on one side but the rotors were a little thin.
Old Jan 10, 2009 | 11:37 AM
GSGALLANT's Avatar
By the way... it doesn't sound like a simple "replace rotors and pads" job. If your brakes were smoking hot, some of your caliper pistons are sticking. You need to either rebuild your calipers, or replace them with new (or remanufactured) ones. When you remove the calipers, check to see which pistons don't move freely.
Old Jan 10, 2009 | 12:46 PM
yota lover's Avatar
How do i check that which ones are moving freely and which ones are not?
Old Jan 10, 2009 | 04:29 PM
GSGALLANT's Avatar
With the pads out and caliper off the rotor, it should be quite easy to press the pistons in with either some large channel lock pliers or a c-clamp. It shouldn't take much force to push them in. Just check that they move freely... don't push them way in, because you can overflow your brake fluid reservoir that way. Also, do one side at a time, and while you're working on a caliper, put a block of wood or something between the pistons in the other caliper (or install it back on the rotor with the pads in place)... just to make sure that you don't accidentally pop out one of its pistons.
Old Jan 13, 2009 | 03:17 AM
pcmentor's Avatar
On the 85 22re power booster there's an adustable plunger rod tip. When I had a guy adjust it wrong my brakes were locking up on the freeway. I believe the adjustment is in the FSM. You remove the master cylinder to access.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
