is it the body mounts or normal?
Old Jul 25, 2013 | 10:17 AM
bryy's Avatar
So I pulled my shifter boot on my 1985 toyota pickup SR5 to start the process for dual cases with tipple sticks.
My whole set up seems to be more to the passenger side(see pics) is this normal? I know my transfer-case and motor mounts should be replaced. My body mounts look good and straight. Anyone else have this issue?
Old Jul 25, 2013 | 11:13 AM
bryy's Avatar
While im on the subject of mounts. where is a good place to find good oem or oem like motor mounts? I Looked threw toyota part zone and it says the LH mount is available but the RH mount was discontinued?
Old Jul 25, 2013 | 11:31 AM
Greg_Canada's Avatar
Your mounts are throwing it off, same thing happened to mine. mine werent even attached LOL
trail-gear makes upgraded mounts
http://www.trail-gear.com/performance-components
http://www.trail-gear.com/transfer-case-mounts
Old Jul 25, 2013 | 02:18 PM
bryy's Avatar
Hey thanks for the reply.
I have two new t-case mounts to go with my duals all ready,
I decided I am going to stay with rubber mounts as I drive this truck a lot for on road reason. I will be adding a chain however to make sure my duals dont rip them in half.
I was looking at the auto zone duralast mounts and after several reviews read on them I think The extra money would be worth the OEM ones after all, the OEM ones lasted 28 years as it is.
With that being said
After searching for mounts here
http://www.toyotapartszone.com/Page_...onentsID=11-07
Right hand mounts are un-avalible, will left hand work for both sides? or any better place to buy OEM mounts?
Old Jul 25, 2013 | 05:38 PM
For my 3vz, both mounts were identical. Unsure of 22remounts tho, sorry.
Old Jul 25, 2013 | 07:08 PM
bryy's Avatar
I tried to do some searching I think they are I might just have to make or bore out a hole
Old Jul 26, 2013 | 06:57 AM
bryy's Avatar
Anyone?
Old Jul 26, 2013 | 09:47 AM
Try posting in the 86-95 forum, WAY more people there that would know.
Old Jul 26, 2013 | 12:37 PM
Stetson_md's Avatar
You should be able to use a rh mount on the left hand side unless you have the bar attached to your right hand mount in which case a lh mount will have to have a hole drilled in itName:  20130726_163016_zps23d7c74e.jpg
Old Jul 26, 2013 | 01:03 PM
Ocell's Avatar
The left and right mounts are the same. You can reuse the bracket shown in the photo above. I removed my mounts without taking the brackets off of the block.
Of course, that may have been because they had completely separated and pretty much fell apart once I got them unbolted.
Old Jul 26, 2013 | 01:45 PM
Stetson_md's Avatar
Btw what dose that braket hook up too? None of our other motor mount/trucks have it
Old Jul 26, 2013 | 02:45 PM
Ocell's Avatar
That bracket bolts to the engine block on the passenger side. It's not technically a part of the engine mount (as in, if you buy a replacement engine mount, you don't get that bracket with it). You can see it above the bell-like-shield of the engine mount here, with the oil filter peaking out from behind.
Old Jul 26, 2013 | 08:49 PM
bryy's Avatar
Well that makes good sense ill just order two from the same side. And check and see what exactly I have going on. Down there
Old Jul 26, 2013 | 09:08 PM
Ocell's Avatar
I just looked at your Toyota Parts Zone link. Are talking about the $80-something part? I think that might be the metal bracket and not the rubber mount. You might want to call them before ordering and check. That's way too expensive for just the mount.
It would also explain why they list one for the right and one for the left. The brackets on each side are different.
Old Jul 26, 2013 | 09:41 PM
rokblok's Avatar
Isn't the bar a support for the intake manifold?
Old Jul 27, 2013 | 04:46 AM
bryy's Avatar
When I throw that part number online all I get is pictures of knock of cheaper rubber mounts.
Old Jul 27, 2013 | 04:52 AM
bryy's Avatar
I did find this though not too much help
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Scotto6591
Sep 1, 2015 03:24 PM
dropzone
Jul 16, 2015 02:00 PM
jon.r
Jul 11, 2015 03:34 PM
