birf snap ring
Old Apr 28, 2011 | 04:22 PM
85 FF / medic's Avatar
birf snap ring
Ok..... just did all the new 3rd member and birfs, now I'm putting it back together and can't get the far outer snap ring on.... everything is torqued correctly but the slot for the ring is not exposed..... going Wheelin in the morning, please help! Thanks
Old Apr 28, 2011 | 04:27 PM
algranger's Avatar
is the axle shaft set all the way into the birf? Hub gear put on in the right direction?
I have wheeled without that snap ring... nothing happened but i dont know if it's the greatest idea
Old Apr 28, 2011 | 04:32 PM
Oh yeah its set all the way in...... if any thing its to far as there is not enough exposed. The hub gear is on correctly I assume as everything else lined up.... thanks!
Old Apr 28, 2011 | 04:37 PM
algranger's Avatar
Oh yea, i was thinking of it backwards.
I don't remember the name of the part but its in the center of the birf, it has a female spline gear that grabs the axle shaft. Is that put in in the right direction?
Old Apr 28, 2011 | 04:45 PM
waskillywabbit's Avatar
Vise grips. Channel locks. Pull the end of the axle out. Install snap ring.
:wabbit2:
Old Apr 28, 2011 | 06:24 PM
yotaman1861's Avatar
Yeah theyre should be enough play in the axle to pull it out enough to get the snap ring on.. If not, there is something wrong somewhere.
Old Apr 28, 2011 | 07:12 PM
Dras16's Avatar
X2. If that doesnt work on the end of some of the axle shafts there might be a threaded bolt hole that you could put a bolt in and get a grip on.
Old May 2, 2011 | 04:46 AM
84Horunner's Avatar
Also check to make sure you set the bearing preload properly. If the entire hub assembly doesnt go far enough on the spindle you wont be able to get to the groove to put that snap ring on.
Wab Fab has directions on how to set bearing preload on his website.
Old May 3, 2011 | 07:13 AM
Thanks guys..... got the driver side on but not the right side.... wheeled it anyway without a problem. I have to pull it all back apart to put propped length wheel studs on so I will reload the bearings correctly. Thanks again!
dzldust
7
Oct 6, 2015 05:39 AM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
Project90
Sep 24, 2015 11:40 PM
