adjusting the rear drum brakes
Old Nov 3, 2010 | 03:13 PM
live4soccer7's Avatar
I just rebuilt the rear drum brakes, but I have one question. How should I go about adjusting them?
Old Nov 3, 2010 | 03:18 PM
xxxtreme22r's Avatar
isn't that procedure listed in the fsm?
Old Nov 3, 2010 | 03:31 PM
Is this really all there is to adjusting it? Just seems like there would be more.
Old Nov 3, 2010 | 03:42 PM
pretty much, some people just use the bellcrank to tighten it up, some people use the e-brake handle while driving in reverse and pull that several times as well. I prefer just manually manipulating the bellcrank till I think it's tight enough where there is just a slight drag between the drum and shoes.
Old Nov 3, 2010 | 04:39 PM
thanks for the input. I'm headin out to bleed the brakes now and then I'll be adjusting them accordingly.
Old Nov 3, 2010 | 06:35 PM
What should the initial drag be? I have to set the cables and the bell crank as well b/c it was completely disassembled cleaned and painted b/c they were rusted through and through. The bell crank wouldn't move at all. Took a lot of pb blaster and a large hammer. I'll start at the spider gear, then the cable will be loosened up a little if need be and then the bell crank. I'm just not sure how to tell how much drag I need between the drum and the shoes when all is at rest.
Old Nov 3, 2010 | 06:54 PM
Thanks for the input. That should do it. I'll most likely be able to get'er all setup with that.
Old Nov 10, 2010 | 11:13 PM
LSUfan71's Avatar
I finished my rear brake job this evening and the instructions in my manual worked fine. I just read those instructions, I'm wondering what I would use to measure the inside diameter of the drum and the outside diameter of the brakes? And be accurate to a tenth of a mm?
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
garagespace
Jul 9, 2015 08:37 AM
87turboPA
Jul 9, 2015 05:58 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
