add-a-leaf or blocks?
Old Aug 29, 2006 | 07:14 PM
mehret's Avatar
I'm sure this has been discussed a thousand times, but digging through all the search results was taking me too long, so I figured I'll take the risk of getting burned.
What are the pros and cons of an add-a-leaf kit and blocks, because, like everyone else, my rear is sagging and I can't stand looking at it anymore. I'm not too concerned with the stiffness of the ride, so I just want to know through past experiences what you guys think, and also, where is the best place to buy either an add-a-leaf kit or a pair of blocks?
Thx
Old Aug 29, 2006 | 07:56 PM
4Crawler's Avatar
A good AAL is the way to go, Rancho Soft-Ride AAL kit is good, 2 pair of leaves you can mix-n-match as needed for the height/quality you want (http://www.gorancho.com/). The Soft-Ride kit includes one pair of long, thin leave and a 2nd pair of slightly shorter, somewhat thicker leaves. You want avoid any AAL kits that just use one pair of very short, very thick leaves.
Blocks will increase chances of axle wrap/wheel hop under load and they will also do nothing to help the oveloaded springs handle the weight that is making that go flat. Also, ride is probably stiff now since the rest of the leaves are sitting on the stiff overload leaf on the bottom. Blocks will not affect that, AAL will lift the rest of the leaves off the overload actually softening the ride from what you may have now.
Old Aug 29, 2006 | 08:20 PM
Chainlink's Avatar
X2 aal is the ONLY safe way(i guess shackles too) but 4crawler is spot on correct read no futher, or get a whole new after market leaf pack, but the aal is cheapest and will work safely
Old Sep 1, 2006 | 04:57 AM
neo's Avatar
neo
i had both on my 79 toyota truck.3 inch cast iron blocks and 2.5 inch
add a leafs on the rear,my sure you use cast iron blocks if you use blocks.do not use cheap aluminum blocks,they will break,on adda a leafs use good ones,my first set one of them broke in half,they were made by TUFF COUNTRY SUSPENSION
i will never use tuff country again also one of my bottom leafs broke at the same time neo
Old Sep 7, 2006 | 02:54 PM
Sonofmayhem's Avatar
blocks are for losers in 10in lifted f250s.
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
viesail
Sep 5, 2015 04:23 AM
