85 xcab rear springs sagging
Old Oct 17, 2006 | 08:10 AM
Texx's Avatar
Wondered what "without lift" options there are for my new to me 85 Xcab. Driver's rear is sagging significantly. Front springs are fine, truck def has an "ass down" attitude. I'm restoring this for my daughter's first car, so want everything stock. Is it possible to get aftermarket springs without lift? Anyone have some good stockers near Tx?
Old Oct 17, 2006 | 08:21 AM
bktaco's Avatar
i think NWOR sells replacement stock springs. i dont know if they are stronger upgrades, true oem replacements will probably end up sagging after a few years tho. i have never dealt with NWOR , but i have heard that they can be hard to deal with.
Old Oct 18, 2006 | 06:11 AM
MtnToys's Avatar
Get some old man emu (OME) springs made by ARB. They are bolt on, the ride is excellent and they flex better then stock. They have 2 inches of lift but if you get the soft ones I bet they would look stock. I have a set of these on an fj60 and the ride is far superior to stock.
http://www.off-road.com/toyota/reviews/ome/index.htm
Old Oct 18, 2006 | 06:32 AM
AH64ID's Avatar
OME, NWOR or ALCAN...
Old Oct 18, 2006 | 08:17 AM
bktaco's Avatar
mtn toys: do the OME springs end up sagging too, or are they beefy enought to hold up longer? i am looking at those springs for my 4runner in the next year or two...
Old Oct 18, 2006 | 08:30 AM
phorunninduke's Avatar
I have an extra set of rear springs. IIRC the truck they came off of still had the right ride height. They where an extra set for the "rears up front lift" that I never used.
They need to be cleaned up but you can have them for S+H (heavy)
Old Oct 19, 2006 | 04:55 AM
Texx's Avatar
I sure appreciate the offer! I'm gonna check around locally, may take you up on that. I need to measure my front height and see if it's lifted. It's on 235's right now, and there's looootttsss of open area...may have a small lift on it already.
Old Oct 19, 2006 | 07:36 AM
4Crawler's Avatar
Add-a-leaf (like the Rancho Soft-Ride AAL kit) or JC Whitney also sells a stock height rear spring:
http://www.4x4wire.com/forums/showfl...t=1#Post931633
Old Oct 21, 2006 | 04:24 PM
rockota's Avatar
Personally, at over 20 years old, I'd replace them. Stay away from NWOR at all costs. The only place I know that sells stock-height springs is JC Whitney. Otherwise I echo the idea of 2" OME springs. Some of the nicest on the planet.
Old Oct 24, 2006 | 04:58 PM
MtnToys's Avatar
I have only had the OME for a year or so. No signs of them sagging. We loaded the truck with 15 sheets of 3/8 plywood and the rear wasnt sagging. Keep in mind this is on an FJ60 but im sure they are similar to the 4runner and pickup springs. I would have installed these springs on my runner in a heart beat if i wasnt looking for a larger lift to fit 35s. I have only ever herd excellent things from others who have used OME.
Old Oct 27, 2006 | 06:19 AM
84TonkaYoda's Avatar
If you are wanting some flex I would go with the All-Pro superflex rear springs. They have a 3" lift to them for only $289 and you are off to having a great lift with more flex than you will ever need. Something to consider.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
terminator
Jul 27, 2015 07:13 PM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
