22re to 3.4 85 4runner help
Old Mar 31, 2015 | 07:15 PM
Humboldt Wheeler's Avatar
i have a 1985 4 runner that i put a 97 3.4 v6 into. when i first tried to start it we didnt have any spark at the plugs. i installed the obd2 plug and before i could plug it in we noticed spark came back. the truck fired right up and i drove it a couple weeks. i tried to run the obd2 codes but had 2 different scanners tell me it couldnt communicate with my vehicle. drove it any way and it ran good. none of the gauges worked to good so i installed some 2 inch euuus. the oil was mechanical and i had to remove the oil sensor to install the port. the temp i installed the sender under the plenium against the fire wall. i removed the 1 wire plug and installed the equus sender running my own wire. i put the battery one where it used to be in the wiring harness . as for the rpm come to find out i shouldnt have put it in its usual spot on the 22re harness. guess itll ground the system. found that out after it woudnt start and thought if i unhooked it the truck would fire up. didnt work...
like always it wouldnt fire up. when i fix ˟˟˟˟ i fix ˟˟˟˟ good lol. started checken and found out the phantom problem came back. i got 12 v to the coil packs but no spark at the plugs. turns over fine and dont even try and fire. i went to the store and spent 100 bucks on a obd2 scanner. weird thing is, i didnt change anything and now all the sudden the scanner is reading.i have 4 codes, one for temp censer 1 for oil censer, mass airflow and tps i believe. thing ran great before i installed the gauges. all fuses and grounds seem fine. im more of a fabricator than a mechanic. thanks for any ideas, im about over this project ps... the engine harness was done by a company in north carilina called tweeked performance. it ran great for 2 weeks so i assume they did a great job. im new to all this ecu ˟˟˟˟.
Old Mar 31, 2015 | 07:23 PM
VIDEO RATED R! (language)
http://vid686.photobucket.com/albums...pskfpf3nbp.mp4
Old Mar 31, 2015 | 07:25 PM
one more thing. all of my fuses and such are all the old 22re stuff. thought that might be usfull info. HELP ME HELP MYSELF! if i dont get this thing figured out by thursday i may take it to my auto eletric buddy. id rather not have too.
Old Apr 1, 2015 | 08:06 AM
wyoming9's Avatar
Red face
Myself I would start reading all the threads in the 3.4 swap section.
Someplace you have a poor connection .
Perhaps even poor grounds.
OBD II plugs can corrode getting the unable to connect message is quite common when I try and pull codes .
Sometimes just unplugging and reconnecting is enough. Other times Electronic cleaner is needed
Old Apr 1, 2015 | 09:15 AM
OldernDirt's Avatar
Thumbs up
Wow -that 3.4 sounds good. I want one!
Old Apr 1, 2015 | 11:32 AM
thats without the magnaflow hooked up but thanks. your right it DID sound good.
Old Apr 2, 2015 | 08:47 PM
broke down and took it to the local auto eletric guy. ill let you know what i find out. . i hope he finds it fast lol
Old Apr 2, 2015 | 10:51 PM
wyoming9's Avatar
Red face
Because this is a swap there will be no fast in trouble shooting .
I hope the company that did the harness sent a schematic showing just what was done.
Best of luck.
Old Apr 3, 2015 | 07:34 PM
BigBluePile's Avatar
Wow that sucks. All my gauges in my cluster worked after my swap.
Old Sep 8, 2015 | 08:44 PM
Berferd's Avatar
Waiting for an update
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
