22R valve train noise
Old Apr 13, 2008 | 02:44 AM
cambelt's Avatar
I thought id ask you guys as you have far more 22R,s than we do in AUS.
Whats the noise that sounds like a tappet noise in a 22R but isnt loose valve clearance. Its not hitting the rocker cover either. I set the valves on the tight side to try and quieten it down and yes the tappet noise is fine now just this other noise . Its not the timing chain , im guessing worn rockers as its worse when hot .
Dave
Old Apr 13, 2008 | 05:22 PM
myyota's Avatar
The rocker arm assemblys on our trucks can wear out and make noise, are you sure its not a rod knock or something like that ?.
Old Apr 13, 2008 | 07:12 PM
SoCal4Running's Avatar
An overtightned vavle cover can cause a vavle clatter type noise.
Old Apr 28, 2011 | 08:15 PM
RogueYota's Avatar
Originally Posted by socal4running
an overtightned vavle cover can cause a vavle clatter type noise.
really!?!
cars-guy
Aug 16, 2020 06:59 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
razorman8669
Jul 12, 2015 12:13 PM
cars-guy
Jul 11, 2015 07:51 PM
