22R valve train noise
I thought id ask you guys as you have far more 22R,s than we do in AUS.
Whats the noise that sounds like a tappet noise in a 22R but isnt loose valve clearance. Its not hitting the rocker cover either. I set the valves on the tight side to try and quieten it down and yes the tappet noise is fine now just this other noise . Its not the timing chain , im guessing worn rockers as its worse when hot . Dave |
The rocker arm assemblys on our trucks can wear out and make noise, are you sure its not a rod knock or something like that ?.
An overtightned vavle cover can cause a vavle clatter type noise.
Originally Posted by socal4running
(Post 50805037)
an overtightned vavle cover can cause a vavle clatter type noise.
really!?! |
