22R rebuild; still smoking
Old Nov 27, 2010 | 09:35 AM
  #61
zuwuko's Avatar
Thanks nothingbetter. I appreciate ur input inmensely. I agree I need to break it in as best as I can. I have never done this so ur input an everyone elses is priceless to me. I'll be fabricating the exhaust today and maybe post some pics. It'll be shorter and route out before the rear tire pointing a little downwards.
Old Nov 27, 2010 | 10:04 AM
  #62
ChefYota4x4's Avatar
Hey Zuwuko,
My engine guy gave me really good instructions for break in, and he actually even recommended using Zinc for the initial 20 Minute break in(it also came with the good CAM lube all over the lobes of the CAM). He also had me use non-detergent oil for the first 20 minutes, then drain it, then 500 miles, then drain and refill again, then change filter and drive 2500 Miles and do it again(I'm not to 2500 yet, but had to change it anyway because of my bad cam/after the swap)
Along with those basics, he gave me RPM variations. "1500 for 8 seconds, 2500 for 8 seconds, 1500 for 8 seconds, 2000 for 8 seconds", etc., etc., hahahaha. Then, when swapping in a new CAM, I had to do that again, because THE CAM is one of the most crucial reasons you're varying the RPM's during initial break in, to allow proper polishing of the lobes so that the duration, etc., stays right on and doesn't damage the new rockers, etc.
Wishing you the best, man! I've been through much of this and I know how nervous I was at first to get it JUST RIGHT! lol.
Best wishes, man,
Mark
Old Nov 27, 2010 | 06:54 PM
  #63
zuwuko's Avatar
Originally Posted by bicklebok
I just joined this group and let me say Im pulling for you zuwuko! You go!!
I have a similar problem with my truck-rebuilt head, now its using a lot of oil. Trying to decide what's the problem, and what to do. Meanwhile, I will follow your project!
thanks! I appreciate the support and encouragement. Why don't you start up a thread with details of a compression test, leakdowm test, and specific symptoms? I'd be happy to give u my diagnostic opinion as well as others here I'm sure.
Old Nov 28, 2010 | 05:26 AM
  #64
bicklebok's Avatar
Well, I dont know if Im mechanically savvy enough to do a rebuild. I can do most mechanical repairs, but I have never been on the inside of a motor. I have been looking at used Tacoma's as a replacement, but they are so expensive! So for now Im just in a delimma on what to do.
Old Nov 28, 2010 | 04:57 PM
  #65
nothingbetter's Avatar
bickle, doing an engine rebuild isn't an act from the heavens. It's all about taking your time and paying attention to all the little details. If you do that you shouldn't have any problems down the road. Think of it this way. Your engine already has issues. If you rebuild it, and it still has issues, your only out some cash but you learn't a lot in the process. But if you rebuild it, do it well, and it runs flawlessly for years to come, you arn't out any $, you still learn't a lot and you still have your truck. As far as I'm concerned, the only way to really learn is to get your hands dirty and do it. You can read about it as much as you want but you will never learn as much as when you hold that piston in your hand and say "so THATS how it works!"
Also, you could just swap your engine for another out of a wrecked truck.
Old Nov 29, 2010 | 04:50 AM
  #66
bicklebok's Avatar
Thanks guy! I dont want to hijack this thread!
im going to do some thinking on what I should do. I have come to the conclusion today that I will NOT be buying a Tacoma anytime soon. I just cant justify that expense right now. So that leaves me with a few options; keep driving the truck as is and keep a gallon of oil with me, rebuild the engine, or buy a used one and install it.
WHats the latest zuwuko?
Old Nov 29, 2010 | 10:28 AM
  #67
zuwuko's Avatar
Fabricating the exhaust. Custom. I'll post up pics when I finish the welding and cutting.
Old Nov 30, 2010 | 01:48 PM
  #68
zuwuko's Avatar
Here is the exhaust. Truck passed emissions with 48 HC LIMIT 200. I failed the Gas Cap though! Thought that was funny. Motor feels good. There is a very tiny small oil leak in the FRONT of the engine. looks like its either right above the water pump to the front cover. OR maybe coming from the "11th" head bolt (small one at the front of the head). Any ideas?
Old Nov 30, 2010 | 01:52 PM
  #69
xxxtreme22r's Avatar
kinda low on the exhaust don't ya think? That's just begging to get ripped off.
Old Nov 30, 2010 | 01:56 PM
  #70
Looks good, Zu! Yeah, though, what X said, lol.. maybe angle it upward out the back of the muffler and then keep it tucked higher up on the tire?
Far as the oil... hmmmmm. Not sure what you mean by the "Hidden Bolt causing a leak". Do you mean maybe it's not tight or maybe you forgot it? lol. I could see if it's missing that the oil could come out the "timing cover/Head" surface.....couldn't it, guys?
Maybe check the easier things, first, like seeing if maybe the valve cover gasket slipped and kinked, causing oil to leak down to the head/block seam and run around to that area in the front? OR, maybe the timing cover has a flaw somewhere or oil is leaking into a bolt channel and out one of the upper bolts? Seems to me, if you're seeing oil that high(from the head/timing cover portion of the HG)...... would lean more likely toward HG/Timing cover top area compromised or Valve cover...no?
Old Dec 1, 2010 | 03:09 AM
  #71
bicklebok's Avatar
Good job Zu! Post us some pics of the engine and the whole truck please. I want to see that jewel!
Old Dec 1, 2010 | 08:34 AM
  #72
zuwuko's Avatar
Its higher than it looks in that picture, I mean its higher than the rear differential (not THAT high but still other things have less clearance). Still a bit low for my taste as well though. I just needed to get it bolted up fairly quick so I could go pass emissions and register the truck. I'm definitely going to fiddle around under there and see how I can tuck it a bit more.
I DID install the hidden head bolt. It is a strange tiny tin tiny leak. I really hope its not coming from between the head gasket area, I really dont want to pull that head of for the 5th time.
Old Dec 1, 2010 | 09:32 AM
  #73
Hey Zu, I NEVER SAID "it was likely" either way, lol... DON'T think that. Just trying to help you track it down. I cannot let oil leaks go, ...they drive me nuts and concern me, as I've had them SUDDENLY become much worse, ya know? lol. You'll find it, and btw, I don't think you HAVE TO pull the head to swap out a timing cover gasket, etc., IFFFFFF that ended up being what it was. OH, yes, I forgot to mention.... ONE TIME, just sharing, lol.... I had a leak that was really giving me trouble in finding... It ended up being the half moon on the valve cover. It was on right, but I'd forgotten the sealant at the corners between the cover and the head(edges of the flat part of the half moon). Just throwing it out there, that's a pretty easy fix, if it's possibly what's leaking.
Watching and hoping for the best.
Old Dec 4, 2010 | 02:00 PM
  #74
zuwuko's Avatar
Chefyota, no worries on misunderstandings. I just use caps to try to clarify as much as possible, not to yell n such.
I'm going to heat n bend the end pipes so it'll have more clearance for that tire.
The measurements of the rear seat is 20"x20", many msgd me for dimensions.
Old Dec 9, 2010 | 09:51 AM
  #75
mgood's Avatar
Just had the exact same problem with mine and my problem was I didn't chase the head bolt holes with a tap causing improper torque of head bolts after I corrected that and got the
e Carb tuned right she runs like a sewing machine.
Old Feb 5, 2011 | 07:40 AM
  #76
zuwuko's Avatar
Well everything is running fairly smooth with the rebuilt motor. Do remember I put a new carb on it as well for the following report: When warm, it idles inconsistently. I dont have a tachometer yet, but it feels as if it fluctuates between about 600 rpms to 1,500 rpms. And of course, when it hits the low point, it stalls 50% of the time. I'm not sure where I need to focus on.
Somewhere I read perhaps it could be a faulty ECU since it only occurs on WARM idle. I'd really appreciate any input, especially from others with previous similar experiences. Thank you.
Old Feb 5, 2011 | 04:53 PM
  #77
yotakeith's Avatar
itll smoke for a bit from oily hands but not that long. when i put mine together. when i was settin my distributor and puttin water in. i would crank it then cut it back off. it smoked like the first 3 cranks which was like 10 mins? since you didnt rplace the rings it could be a broke oil ring. possibly?
Old Feb 5, 2011 | 06:53 PM
  #78
zuwuko's Avatar
Yotakeith: Thanks for your input, however, I had a local machine shop build the block. I reassembled everything in my garage. No smoke, its running fine. It was the rings that werent sealing, the cylinder walls were scored.
Old Feb 5, 2011 | 09:11 PM
  #79
yotakeith's Avatar
oh. well i was about to say they the rings havent seated. that can take a while sometimes. but ok. goodluck!
Old Sep 2, 2012 | 05:07 PM
  #80
zuwuko's Avatar
I never got around to posting more pics of this process. Here are some Pictures taking the block out in my garage with some friends instead of a cherry picker.
I ended up selling this truck. I now have a 1994 Nissan Patrol TD42 (4.2 Diesel inline 6 cylinder) with 680,000km running straight veggie oil like a champ.
But I hope to be selling it soon to buy this 96 4Runner 2.8 Diesel tomorrow if all goes well. Any particular things I should look to inspect?
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Nickyodaman
Jul 27, 2015 12:13 AM
Jonny246
Jul 24, 2015 12:37 PM
