2.5" pro comp leaf?
2.5" pro comp leaf?
i have a 85pu, i want pro comp springs on it but my problem is i can only find 4" lift springs, i dont want 4" though. i know they have 2.5" leafs but i have never seen one for my toyota, i was wondering if anyone has 2.5 springs or if i can get springs for another vehicle that will fit mine. any suggestions will be helpful
I can tell you right now from my truck with the 4" Procomp lift you're not going to get a whole lot of flex out of them. Could be other factors regarding how my truck is set up... but you can see from the pic I have with the back passenger wheel in the air that there isn't much give. Once again could definately be other factors on how its set up... Just a newb here offering my 2cents.
actually, flex is important on a baja setup too. if the springs are too stiff, you'll bounce over the whoops instead of letting the springs absorb them.
instead of springs, you might check into extended rear shackles.
ya im okay with that, heres the whole thing. my springs are frowning so i need new ones, i can only find the pro comp 4" thing is, i like my stock heighth and i dont wanna go up 4" cuz thats pretty tall.. so a 2.5 would be perfect
they dont have 2.5 but 2 you would probly like better if you like the ride height you have right now.
downey makes good stuff and they have good warrenties, they should be stock replacments i would give em a call if i were you, also heres another option. http://www.oldmanemu.com/store.html?...ax=10&start=21
old man emu stuff is also very high quality
Brodetski
Sep 30, 2015 11:50 PM
Odin
Sep 26, 2015 06:56 PM
