1985 4 runner with 22RE - Mystery plug
Old 11-15-2006, 05:17 AM
Doc279's Avatar
I found a plug on the engine harness that I can't identify. The plug is just below the intake runners and above the starter. Can anybody help indentify what this plug is for and where it goes ?
I am having cold start issues - the initial start each day is a long crank to get running. The engine starts fine the rest of the day.
Here is the mystery plug:
Old 11-15-2006, 05:53 AM
phorunninduke's Avatar
I believe that plug has something to do with automatic transmissions.
Old 11-15-2006, 06:08 AM
Doc279's Avatar
I have a 5 speed manual tranny.
Old 11-15-2006, 08:07 AM
4Crawler's Avatar
I have the same, unused green plug on my '85:
As noted, I think it is part of the A/T wiring, probably for the coolant temperature sender. On an M/T truck, it is not used.
Old 11-15-2006, 01:22 PM
I guess it was too early in the morning for me. I meant to finish my statement with, " it is unused if you have a manual transmission."
Old 11-15-2006, 01:40 PM
waskillywabbit's Avatar
Yep, I have one on both of mine...I always figured it was an AT thing.
Old 11-15-2006, 01:42 PM
Elton's Avatar
i have lots of unused plugs on most of my toyotas
Old 11-16-2006, 07:33 AM
84sr5yoty's Avatar
95% of the time the cold start injector time switch is what causes this problem. It can be ohmed out but I have the specs on hand at this time; maybe someone else will chime in.
Old 11-30-2006, 07:26 PM
toyota_mdt_tech's Avatar
No way, cause you are dead one! Its a 2 pin connector, and on the 85, should be brown in color, mount on the front of the intake. But it could be green in color, but it will be 2 pins!
Old 11-30-2006, 08:53 PM
85TurboRunner's Avatar
i dont have much to offer on the plug, but you have a very clean engine bay, looks good.
Old 12-01-2006, 04:48 AM
Doc279's Avatar
I keep it clean on purpose ! I don't like to get dirty everytime I raise the hood ! It also helps to pinpoint problems before they become bigger !
It was pretty dirty when I purchased the 85, 6 months of tinkering and tweaking and it is coming together. I'm daily driving the 85 and I travel
during the week. I logged 1000 miles this week.
This thing is a TROOPER ! I can run 70 - 75 miles an hour and I'm getting about 19mpg. It don't shake, rattle or complain - I LIKE it !
voiddweller
19
05-02-2016 09:10 PM
DacodaYota
09-02-2015 02:13 PM
puddlepirate
06-30-2015 05:08 PM
Eagle564
06-23-2015 11:29 PM
JaredL
06-16-2015 04:47 PM
Quick Reply: 1985 4 runner with 22RE - Mystery plug
