Resurrecting an 80 that sat for years
Hi all, newb to the old Toys but not to wheeling or mechanicing.
I just picked up an 80 longbed. It has been sitting for years. Came with 3 dead batteries an extra bad motor a couple buckets of parts, rust, dried out stuff , aftermarket seats with no mounts,bad clutch master cyl a lift and 33s and some hack mechanic work.
After inspecting it there are mutliple sensors/ sensors on the intake with no
wires. Ive never tried to restart a vehicle that has been sitting.
What should my process be? Has clean oil in it. The air filter base gasket to carb is dried out junk.
Thanks for any help or suggestions in advance. - A
I would pull the plugs and squirt some marvel mystery in the cylinders maybe a tablespoon or so. Use a turkey baster to squirt it or whatever you feel lilke using. Let it sit overnight. Then the next day pull the plugs again to alleviate pressure while your manually cranking or turning the engine to get things moving. Then wait a little while and do it again and give it a crank when you can.
Cant hurt to try and get it running! I also have an 80 in about the same shape, got it running and found out the head was warped beyond repair. But i had fun figuring it out and learning about these trucks!
When I was in high school I bought an old 71 firebird that hadn't moved for about 10 years. It was a blast! I enjoyed working on it very much. It never looked good, but it was ok for in high school. I thought about fixing it up but I decided I wanted a 4runner, so I sold it but I really loved the experience of taking it from almost nothing, to something that I really enjoyed.
I would echo what the others said. Drain oil, drain fuel (hopefully there is some in there so the inside of the tank isn't rusted out), change filters, turn engine by hand before you start to make sure it moves freely, and have fun with it. You might have to spend a lot of money in the long run, but you don't have to spend it all up front.
Also make sure you check all fuel lines if any are rubber. I had a dry cracked leaky one that I thankfully found before my engine compartment set on fire. Make sure you check the tires after running them a while to make sure they aren't rotting away. Sometimes when they've sat they look fine and then fall apart soon after being used again. Heat kills rubber. Hopefully you don't live in a desert.
well I plulled a plug and looked inside, no rust. Turned it over by hand, has compression.
Borrowed a battery and dumped some gas in the tank and the carb and it will run off what is in the carb. I think the fuel pump may be bad or cracked lines who knows. Its hunting season now so it can sit a bit longer.
pyramid
Jul 30, 2015 10:05 AM
