Pre 84 Trucks 1st gen pickups
Rear axle O-ring
Old Aug 29, 2011 | 01:18 PM
Zack1983's Avatar
Rear axle O-ring
So I am almost(fingers crossed) ready to put my rear axles back in and I am having a hard time finding the correct o-ring that goes between the end of the axle and the brake backing plate. None of the auto parts stores I have gone to have any info on that part and o-rings in there were too messed up to get any good idea of the actual size. I made a tracing of where the axle sits and tried to find something at the hardware store, but they only had stuff under 2 5/8'' and over 3something. Does anyone have a dimension or a part number for this piece so I can get the right one. I have seem rear wheel bearing kits with the o-ring, but they never have any dimensions listed.
Any help is greatly appreciated.
Thanks
Zack
Old Aug 29, 2011 | 01:20 PM
peow130's Avatar
theres no o ring... theres a giant seal, but no o ring.
Old Aug 29, 2011 | 02:18 PM
BMcEL's Avatar
Yes there's an o-ring:
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
But...a lot of guys just use FIPG. Not sure on a part number but your local Toyota dealer can get it for you.
Old Aug 29, 2011 | 02:20 PM
4Crawler's Avatar
http://www.marlincrawler.com/axle/re...ar-axle-o-ring
Old Aug 29, 2011 | 02:23 PM
BMcEL's Avatar
There ya go! The dealer probably wants $100 for the o-ring anyway.
Old Aug 29, 2011 | 03:38 PM
Zack1983's Avatar
I guess I will have to call the dealer. I was hoping to get some dimensions so I could just try to get something at home depot, but I guess I will have to see if it is cheaper to get the parts from the dealer or order them all the way from cali.
Old Aug 29, 2011 | 03:48 PM
BMcEL's Avatar
Do you have a tape measure? If so, measure the end of the axle housing and there's your dimensions. As mentioned earlier you can always use FIPG instead of the o-rings.
Old Aug 29, 2011 | 03:54 PM
waskillywabbit's Avatar
If you don't know, please don't spread bad info.
Oring at dealer under $5 each. Mine keeps them in stock.
:wabbit2:
Old Aug 29, 2011 | 04:06 PM
BMcEL's Avatar
I don't see any bad info except the $100 comment which was a joke. Guess I should be more careful.
Old Aug 29, 2011 | 04:09 PM
Zack1983's Avatar
Thanks for all the info. I will try the dealer and see what they say. I just inadvertently bought myself some more time when I broke my homemade special service tool to remove my rear wheel bearings. Back to the garage after dinner for some cutting and welding. I guess it is a good thing that I got some more cutoff wheels today, but then again if I didn't have them I bet the tool would not have broken.
Old Aug 29, 2011 | 05:11 PM
slacker's Avatar
OE part #
90301-88077 $4.62 RETAIL
Old Sep 9, 2011 | 04:38 PM
peow130's Avatar
Pack sand
Every axle i've pulled apart hasn't had that O'ring.
Old Sep 9, 2011 | 04:52 PM
Originally Posted by peow130
I pack sand
Then the POs were WRONG too!
:wabbit2:
Old Sep 9, 2011 | 06:16 PM
peow130's Avatar
:wabbit2:
it's highly possible, i mean, one set i basically dragged out of a junkyard lol.
Old Sep 9, 2011 | 06:25 PM
BMcEL's Avatar
Old Sep 12, 2011 | 10:14 AM
enigmaT120's Avatar
I just got a pair from the Salem, OR dealer. I think the 5 dollar price sounds right, though he only had one in stock so I had him mail the other one to me. The shipping was more than the O-ring, sheesh. I haven't installed mine yet. Three separate seals per side in those axles, and they still leak. Crazy.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
toyoda8488
Jul 5, 2015 10:18 PM
