Pre 84 Trucks 1st gen pickups
oil blowby every where
Old Jul 23, 2013 | 08:12 PM
gmack192's Avatar
My truck is puking oil out of the valve cove vent tube, valve cover, dip stick, timing chain cover and front seal... At least that is what I can see.
I did replace the oil pump tonight, the one that was on it was reading 80 psi when the engine was up to 3500 to 5000 rpm... I thought that might be to much.. the other oil pump runs at about 60 psi...
Any how I am stumped, any ideas??
Old Jul 23, 2013 | 09:13 PM
nothingbetter's Avatar
Sounds like your crank case isn't venting. Start taking it apart again and make sure everything is in the right place. If it wasn't leaking before you changed it, it shouldn't leak after unless something went wrong.
Old Jul 23, 2013 | 09:23 PM
Chickenman's Avatar
Usually the oil pump puts out 10psi per 1000rpm.
Old Jul 23, 2013 | 09:28 PM
gmack192's Avatar
It was leaking before the oil pump swap...The PCV is working but it still has a LOT of blow by out the vent..
Old Jul 23, 2013 | 11:07 PM
gmack192's Avatar
I got a friendly warning about the title of this thread.. I apologize if I offended anyone.
I was going to attempt to change the title, but it appears that has already been taken care of.
I have a BAAAAAAD feeling I have some busted rings...
Old Jul 23, 2013 | 11:09 PM
Chickenman's Avatar
Blow by means rebuild time!
Old Jul 23, 2013 | 11:37 PM
gmack192's Avatar
I built this engine about 4 years ago... But I also let my son use (abuse) the truck for about 8 months. The timing chain broke on it while he was using (ABUSING) it. I tore it down twice since (pulled the head) and the cylinder walls looked good, but I didn't pull the pistons....I have to decide whether to rebuild it again or buy another long block.
Old Jul 24, 2013 | 05:31 AM
Do a compression and leak down test. It is possible that your head gasket is leaing into an oil galley.
Old Jul 24, 2013 | 08:26 AM
enigmaT120's Avatar
What they said. Is one of your spark plugs suspiciously oily?
Old Jul 24, 2013 | 09:49 AM
gmack192's Avatar
The plugs look good...
I have to work the next few days, but will do a compression check before I pull it.
The head gasket is a few weeks old.. The number 1 plug stripped out and I got shavings in the cylinder...So I pulled the head to clean it out.. I lapped all the valves at that time, they looked good. I also replaced the valve stem seals
Old Jul 25, 2013 | 06:10 PM
gmack192's Avatar
Found a 85 Buick 231 V-6 with an MSD distributor and Elderbrock intake, 80,000 miles.
I do have a brand new Holley carb...
I am still undecided as to which way to go.....
Old Jul 25, 2013 | 06:27 PM
Team420's Avatar
Fill that biatch wit k-1(kerosene) and run for 20-30min at idle... Maybe goose it a couple time times. drain and refill, run for another 29 min, drain and refill, then see where you at. May just have some sludge build up
Or... its time for a rebuild, and this ^ could be a waste of $
Old Jul 25, 2013 | 06:31 PM
gmack192's Avatar
It is CLEAN inside and (was) out... I am anal about maintenance..
Old Jul 25, 2013 | 06:53 PM
Team420's Avatar
Did you own it from day 1? Have you ever had her totally apart? If the answer to either of those questions is NO, refer(not reefer ) my previous post
Old Jul 25, 2013 | 07:48 PM
gmack192's Avatar
I built the engine about for years ago... I let my son use (abuse) the truck for about 8 months.. In that time he blew a freeze plug (it was cold) warping the head.. Then he broke a timing chain.. When I replaced the chain, I went lapped all the valves just because, but I didn't pull the pistons... The cylinder walls looked good..
Old Jul 25, 2013 | 08:02 PM
Team420's Avatar
Well...sounds like he beat it to submission then,,,,
Might still try the k-1 trick to free uo any sludge,,its cheap....
Old Jul 26, 2013 | 10:52 PM
gmack192's Avatar
Cylinders #1 #2 & #4 top ring broke in multiple pieces.. Pics in the build thread..
Old Jul 28, 2013 | 05:02 PM
gillesdetrail's Avatar
Can't that be because of a timing (detonation) problem?
Old Jul 31, 2013 | 09:24 PM
gmack192's Avatar
I believe it has been an ongoing problem that was made worse by the DUI distributor...When I got it all pulled down, ya can tell it got HOT. And the block is TOAST......
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
