Pre 84 Trucks 1st gen pickups
New Yota any suggestions?
Old Aug 28, 2009 | 08:47 PM
82offroadyota's Avatar
so this is my first yota, got a hell of a deal... just couldn't pass it up. im planning on putting at least a 3-5 inch lift with some 33's, exhaust, you know... the works. also gonna put a weber carb on it. and thats about it, just put new 4.10 gears in her. anything i need to know about this particular model or what? its an '82 deluxe, manual tranny, with ONLY 94k on it.
Old Aug 29, 2009 | 07:50 AM
80Yoda63B's Avatar
i just got an 80, love the truck, idles kinda funny, buddy at autozone said those Aisan carbs are complete junk, weber or holley is the way to go, what all did your gear swap consist of
Old Aug 30, 2009 | 09:23 AM
not sure really the guy i bought it from just put them in the day before i bought it
Old Aug 31, 2009 | 05:38 AM
83's Avatar
83
People who work at autozone...well I won't say any more. The Asin carb is complicated, yes, but it's better than anything aftermarket. Webers are good, and simple, but at least in my opinion and many other people's who know what they're talking about, the stock Toyota carb is superior to anything aftermarket.
I think if you plan on going any bigger than 33's, different gears than the 4.10s may be in order. Those early 5 speeds were not strong, so listen to your tranny, and try not to lug the engine. They are good trucks, have fun! Can't think of anything else..too early.
Old Sep 16, 2009 | 02:26 PM
suncomb1's Avatar
Three inch suspension lift allows 31-33" tires. 31" tires require 4:56 gears and 33" tires require 4:88 Gears. I run 4:88 gears with 31" or 33" tires. I don't like body lifts and with a 3" suspension lift, the right shocks, chassis components, etc. you can still slalom, oh ! showing my age, sorry drift with you truck.
Old Sep 16, 2009 | 02:33 PM
algranger's Avatar
Too bad you just put 4.10's in, with 33's you would want somehting a little lower but thats ok.. it wont be too bad
You dont need lift to fit 33's but if you like the look then go ahead and lift it.
If you wanna wheel it dont waste your time with a lift until you need it. Start with a rear locker and when you feel that you need the stability of flex and clearance of bigger tires go ahead and lift it
Dont trust the guys at autozone.. theyre out to get you
Old Sep 16, 2009 | 02:34 PM
slisdexia's Avatar
all you need to know is the skinny pedal makes it go!! drive it and then drive it some more.
Old Sep 16, 2009 | 02:36 PM
algranger's Avatar
catusphile
10
Jul 27, 2020 02:38 PM
mbomberz1
Aug 8, 2015 06:57 AM
priest16
15
Aug 6, 2015 07:43 AM
RBK
Aug 2, 2015 11:33 AM
