Pre 84 Trucks 1st gen pickups
my toyota experience begins!
Old Dec 23, 2011 | 12:15 AM
  #121
igotit's Avatar
its 3:13 am ....i have the old 81 parts truck running right now in the backyard,im thinking about swapping the engine into my camo 82.
the 81 runs alot better,has a weber carb.feels more powerful aswell.
the axel code also starts with g.
Old Dec 23, 2011 | 11:56 AM
  #122
RMP8080's Avatar
This may help you w/Toyota Differential Identification
http://www.off-road.com/trucks-4x4/t...ion-18588.html
Old Dec 23, 2011 | 12:19 PM
  #123
igotit's Avatar
thanx for that link,im trying to understand it.
sofar i g for 8 inch ring dia...trying to get the 082
the 08 in the next colum states 4:11 ....then the 2 is alone,in the other colum 2 and another number are paired.
Old Dec 23, 2011 | 12:34 PM
  #124
igotit's Avatar
i think i got it
go82
g = 8 inch ring
08= 4:11
2= 2 pinion diff
right?
Old Dec 23, 2011 | 08:08 PM
  #125
igotit's Avatar
heres the donor 81 engine running,i may do the engine swap!
Old Dec 23, 2011 | 09:29 PM
  #126
RMP8080's Avatar
Originally Posted by igotit
i think i got it
go82
g = 8 inch ring
08= 4:11
2= 2 pinion diff
right?
That sound about right, always check it but 411 common in US Toyota
Old Jan 8, 2012 | 05:44 PM
  #127
igotit's Avatar
dont get your hopes up,but in 2-3 weeks ill be doing an engine swap.taking the nice running engine from my 81 parts truck,putting her in my 82.
in febuary im buying 4 like new 31 inch dc mud country tires with 1k miles.
getting the 33's off.
hopefully all this will give more power to drive the interstate with ease,maybe boost my mpg from 12-14 up too 15-18.
also gonna ghect out the gear ratio on the 81 axels.
the 81 has 31 inch buck shots and weber carb,its alot more powerfull and excellent acceleration.
i know the bigger the tires,the more power you lose.
Old Jan 15, 2012 | 03:42 PM
  #128
igotit's Avatar
pulling the 81's engine now,ill update soon.
just a routine clean up and tune up,no performance mods.
has a weber carb there already,new clutch,needs water pump though.
Old Jan 15, 2012 | 05:07 PM
  #129
igotit's Avatar
got the beast out,fought with a stuck pilot bearing for an hour.
took 2.5 hour to pull a running 22r.
looks like my 81 has the beefy cast iorn l45 tranny.
am i correct?
Old Jan 18, 2012 | 04:51 AM
  #130
southernZ's Avatar
You can id your trans on the rag riveted to the firewall... looks good. A little decreasing and she will be good to go. Are you gonna put a new clutch/to bearing while its out?
Old Jan 18, 2012 | 03:35 PM
  #131
igotit's Avatar
clutch and bearing isnt old,disc is pretty thick,no bent fingers on the plate...im gonna chance it.
clutch felt great when i drove the 81.
Old Jan 20, 2012 | 06:22 PM
  #132
igotit's Avatar
pulled the 82 22r tonight,2-2.5 hours.
Old Jan 20, 2012 | 08:49 PM
  #133
RMP8080's Avatar
Must be warm down there?
Nice on the pull, it's better to be putting one in then out. Doing my 22R pull this weekend but it's snowing now and back to work Monday it going to be in the 40's.
Old Jan 20, 2012 | 10:23 PM
  #134
ThomasByota's Avatar
crazy I hope you get it all running and all goes well.
Old Jan 20, 2012 | 10:47 PM
  #135
kayakken's Avatar
I did a swap on a 84 long bed awhile ago
nice job on your swap and keep us tuned in
btw the beer on your bumper ....LABLE OUT LOL
Old Jan 21, 2012 | 03:39 PM
  #136
igotit's Avatar
thanx guys....temp is in the 70's,very humid....odd for this time of year.
swaps going good,swapping out water pump,fuel pump,adding power steering,taking away ac....ect.
heres the 81 22r strip down.
waiting to buy the water pump gasket before i go too far...some degreeser...ect.
and most importantly....label out per request!
Old Jan 22, 2012 | 03:25 PM
  #137
igotit's Avatar
degreesed quite abit,no pressure washer though.
flushed heater core for 30 mins,it was plugged up pretty bad...bunch of rusty/muddy crap came out.
ordered a new water pump and gasket.
nothing exciting.
making plans to come up with an adapter to install my mitsubishi 2.3 turbo diesel into the rig.
its a mitsu 4d55 td from my 87 ford ranger,the ranger put out a whopping 45-50 mpg,86 hp around 140-150 lbs torque.
revs to 7 k redline.
expensive to work on though....eats a $300 starter every 6-8 mths.
the 4d55 is going in the 82 or the 93 yota.
Old Jan 23, 2012 | 02:10 PM
  #138
igotit's Avatar
fuel pump,water pump,power steering all bolted on.
new cap,plugs,wires and rotor installed.
swapped alternators....thats when i found a problem.the last week i drove her,i had swapped the battery,and starter,only to still get jumped off everyday.
my volt meter showed 12-13 in idle,higher the rpm....the lower the meter read,down to 6 volts
someone put a different alt,and plug onto the stock harness,the white hot wire green connection was toast.
good thing i got a parts truck!
swapped the harness and alt,installed a good coolant tank ect.
all thats left is installing engine into truck,and fabbing up a throttle cable connection.
the weber's butterfly rotated the opposite dirrection as the stock carb.
probally figure this out before i drop the engine in.
Old Jan 23, 2012 | 03:40 PM
  #139
igotit's Avatar
shes in the bay....gotta step away for a few hours though.after midnight....back to work.
hanging in place,20 more bolts,a few plugs,starter,hoses....ready to fire up.
heres the alt plugs that were wrong/ burnt on the truck....hope it didnt cause more damage.
and my ghetto engine pulling system for 1 man with limited stuff.
Old Jan 24, 2012 | 10:13 AM
  #140
igotit's Avatar
i just fired her up,figured out the throttle linkage,had to swap over alot of plugs on the harness.
the 81 has plenty square plugs,the 82 has plenty round plugs....same amount of wires,just different shape plugs.
the throttle is tight to push,due to my setup.ill redo this later though.
all thats left is the radiator/fan/shroud,change the oil sending unit,tidy up a few things...ect....then a test run.
wish me luck.
if only this rain would let up....lol
