Pre 84 Trucks 1st gen pickups
L series transmission clutch fork/throw out bearing question
Old Feb 26, 2013 | 03:59 PM
bushrider's Avatar
I have a 79 Toyota that had the original 4 speed l43 transmission & 20r , I have just built a 22r and acquired a 5 speed l series transmission , I am unsure what state it's in or at this point what trans it is l50 or l52. It did not come with a clutch fork or release bearing to reference..
Will the clutch fork , and throw out bearing , adjustable rod from slave to fork work from the 79 l43 ? It's a cast fork..
I also have a clutch fork (forged steel) & pilot bearing , non adjustable rod from a 1984 pickup g52 trans .
What should I do, unsure what fork I should use...
Old Feb 26, 2013 | 04:52 PM
slacker's Avatar
forks are interchangable .. you just need to reuse the hub for the throw out bearing and the clips for the 79 (you need to find this) . Pilot bearings are the same .
adjustable slave cyl is also used in this scenero
Old Feb 27, 2013 | 05:53 PM
dropzone's Avatar
Fossilized
a little L-Series transmission trivia
L-43 side shifter:
Top one might be an L-50, will have to check with TrekkerPaul, gave it to him for scrap...bearings etc are shot to crap
bottom one is an L-52 based on this tidbit:
Originally Posted by BigMike
Since I am at work right now, I asked Marlin if there are any other ways than what I mentioned, and he said to check if the nose cone has an oil seep hole right on the release bearing section of the nose cone. If so then it's a L52. It is a small 1/8" or 1/4" hole (I don't know the actual size) and it's positioned on the machined release bearing section of the nose cone straight down at 6 o'clock. Marlin said he'll simply reach into the bellhousing and grab the nose cone, and immediately he'll know if it's a L50 or L52 if he feels that hole or not.
That is much better than removing the nose cone, so definitely cool, thanks Marlin!
BigMike
now this is where I thought things were a little wierd. I got to thinking I might as well put in a new throw out bearing in before I swapped transmissions.
here is what I found:
bottom: L43 (out of an '80) throw out bearing and pivot -heavy duty cast piece
middle: L50? (came out of my '81 originally) stamped pivot
top: L52 bearing and stamped pivot (lack of a better term)
this is what I found an interesting bit of trivia- the ears that hold the bearing to the pivot are all different shapes and sizes..
bottom-L43 long and tapered mounts for the clips:
middle= L50 wide and long mounts for the clips
top L-52 wide narrow:
left is L52, Middle L50(?) with a lip for the bearing to mount on, right L43:
does this make a bit of difference on the throw out bearings...dunno, just thought i would throw out what I found...
I am using the bearing thing with the lip on it...
by the way, I am gonna invest in a press sometime..getting bearings off is a PITA
Old Nov 3, 2013 | 05:09 AM
duckmaster88's Avatar
I'm highly confused I have the same problem can I use my clutch fork from my L43 on my L52 and just change the carrier? Or am I looking at find a L52 fork? Are any other years compatible?
Old Nov 3, 2013 | 07:50 AM
catfish21's Avatar
I'm gonna try and call marlin or get on there forum but I think what you have just has to match your throwout bearing collar
Old Nov 3, 2013 | 08:26 AM
cman1's Avatar
you WILL need the l52 fork and bearing. sorry for the confusion.
Old Nov 3, 2013 | 08:29 AM
Originally Posted by cman1
use your l43 arm. i just did this.
Thanks man! Will I have to do any modifications to make it work? Also I'm using this l52 on a 20r which should be the same process but I'm not positive.
Catfish thanks man I'm really looking forward to meeting up and putting this thing in if I skip out on college we should get something going in Louisiana where people get together and fix and wheel although I personally am more into light wheeling
Old Nov 3, 2013 | 08:51 AM
cman1's Avatar
should be,pretty sure the bolt patterns from 20,22,22re are the same.
Old Nov 3, 2013 | 08:54 AM
Ok well thanks man! Everything seems to be working fine?
Old Nov 3, 2013 | 02:42 PM
cman1's Avatar
its my DD and been in since spring!!! works awesome.
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
PlayAwhile
Jul 20, 2015 11:36 AM
