Pre 84 Trucks 1st gen pickups
Help Needed: Headlight issue
Old Apr 30, 2007 | 02:17 PM
dropzone's Avatar
Fossilized
I have got an '81 4x4.
problem: Driver's side Headlight is dimmer than Passenger side.
I have replaced the light, still dim, replaced the ground wire. Still dim.
Cleaned the Headlight connection with baking soda, contacts are now clean.
I have not started in to the headlight switch etc. Chilton's was not much help.
Is there a relay or something else easy that could be bad (relay etc)?
thanks,
Robb
Old Apr 30, 2007 | 03:46 PM
Firefightertaco's Avatar
could try going to 4crawer.com and get his up graded wiring harness
Old Apr 30, 2007 | 04:54 PM
My814x4's Avatar
Try replacing the headlight fuse should be one for the rt and one for the left.
Old Apr 30, 2007 | 05:52 PM
dropzone's Avatar
Fossilized
Thanks! I appreciate the input. I just dug through a box of stuff a friend gave me and remembered there was a PIAA H4 harness similar to what 4crawler sells. I will try the replacing the fuses first..I was braindead
Old May 1, 2007 | 08:11 PM
myyota's Avatar
You might try replacing the headlight relay, i don`t know if it will make a difference but its worth a try.
Old May 1, 2007 | 09:20 PM
4Crawler's Avatar
Make sure the harness is set up for switched ground operation. You may find the high beam indicator will not work if the wrong type of harness is used. Will need to keep track of where the dimmer switch is to figure out if the high beams are on or not:
- http://www.4crawler.com/4x4/CheapTri...shtml#TechInfo
Old May 3, 2007 | 04:58 AM
dropzone's Avatar
Fossilized
Roger:
Thanks for the info. If the PIAA harness did not work (it is) I was gonna be placing an order for one of yours. I had checked the fuses, relays etc and did not find the culprit. With the Hella H4's I put in it is pretty easy to tell the high/low. I do need to go through the dash lights and replace them all.
I love tracking down 25 years and who knows how many owners methods of fixing stuff. Scored a FSM for '81s off ebay. It is gonna be worth it just for the electrical
Robb
Old May 3, 2007 | 06:43 AM
4Crawler's Avatar
Good find on the '81 FSM, that should help a lot. At least you can find out the way it should be wired and find out what has been added/modified. And yes, putting switched power/aftermarket devices/wiring onto a switched ground system like the Toyota is tricky at best.
nvdesertrunner
May 11, 2020 08:18 PM
ghostmoney
Jan 28, 2018 11:42 AM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
