Pre 84 Trucks 1st gen pickups
front drive line broke off
Old Jan 5, 2011 | 09:14 PM
model84's Avatar
I have an 83 pickup and the last time I took it out 4x4 I was hill climbing with slight flex. As I climbed the hill about half way up all four of my front drive line bolts broke and the drive line fell off. Since that issue I had the front diff serviced with no issues but still worried about putting the drive line back on. Any thoughts on the issue?
Old Jan 5, 2011 | 09:23 PM
dropzone's Avatar
Fossilized
make sure you inspect your nuts and bolts before you head out
inspect your TC for cracks. if your DS separated at the splines, make sure it is in phase (google that, not sure how to explain it but know that it is important)
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old Jan 5, 2011 | 09:24 PM
justin_4runner's Avatar
if they have not found any problems it could of been bad bolts, rusted or something and u just put too much stress on them and they broke. replace and keep offroading it.
Old Jan 5, 2011 | 11:39 PM
wyoming9's Avatar
Red face
You did have the factory bolts in the driveshaft??
I tried just regular grade 5 bolts long ago nothing but trouble.
For those bolts to have broke they were loose
Old Jan 6, 2011 | 08:28 AM
rattlewagon's Avatar
Always watch your nuts.
Old Jan 6, 2011 | 09:01 AM
scuba's Avatar
Bolts and nuts probably were not torqued properly. Same happened to me BITD when only 3 out of 4 of the front DS flange bolts were installed. A couple of them worked loose, then I gave it enough skinny pedal and BAM. Everybody thought I broke a CV but it was the front drive shaft. Don't ask me what I was thinking going out like that.
Old Jan 13, 2011 | 11:13 AM
mlrtime99's Avatar
OC, I recently drooped my year axle too far and the rear driveline separate, no big deal except it's out of phase now and vibrates like a mofo. I took it to a show explained that the yoke just needed to be clocked until it was back in phase. I get it back and they've welded weights to it and the damn thing is still vibrating. I'm planning on cutting the weights since the driveline was perfectly balanced before but how do I get it back in phase?
Old Jan 13, 2011 | 11:20 AM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
Old Jan 13, 2011 | 11:29 AM
mlrtime99's Avatar
NVM... got it... haha beat me to it, thanks!
Old Jan 13, 2011 | 12:17 PM
blake.nemitz's Avatar
the bolts on an 81 are smaller than later years you could get new ds flanges and yokes and get bigger bolts or use grade12 if you can find them
Old Jan 13, 2011 | 07:27 PM
model84's Avatar
Still front drive shaft problems
I have an 83 Toyota pickup and was having some front drive shaft problems. I just serviced the front dif. put the drive shaft back on with stronger bolts and took it on the trail. In 4wheel drive I now have a knocking or clunking noise that seems to be coming from the drive shaft. Some say its U joints others saying grease the shaft. Any thoughts?
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
