Pre 84 Trucks 1st gen pickups
Engine trouble help asked for.
Old Dec 7, 2008 | 07:02 PM
Scooby098's Avatar
my engine is well miss fireing and backfireing through the carb , this is after I pressure washed it. my friend things its electrical but could it also be something clogged in the primary jet? its really running like dog so yah any ideas Ive checked the distributor, and im going to take the top off the carb tommmorw and check my plugs but there is no oil in the radiator, so It dosnt look like the head is cracked. again any suggests would be awsome thanks again.
Old Dec 7, 2008 | 08:30 PM
9am4x4's Avatar
my motor did that after i had the plug wires crossed and wrong..(plus 4 wasn't plugged in at all). it shot 1.5 foot fireballs straight up outta my weber and scorched my hood
Old Dec 7, 2008 | 11:13 PM
scooper's Avatar
Could have a bit of water in the carb or settled into the socket that the plugs themselves go in. It could have also gotten into the rotor cap =) Best of luck to you.
Old Dec 7, 2008 | 11:57 PM
Scooby098's Avatar
thanks ill be sure to check all that and see what the progress is.
Old Dec 8, 2008 | 12:20 AM
refried's Avatar
clean the water out of the distributor cap
Old Dec 8, 2008 | 12:30 AM
Scooby098's Avatar
I tryed that today, seemed to run a bit better then squirted some wd40 it was raining for most the day so gonna take another wack at it. definitly not gonna powerwash my rig any time soon after this lol
Old Dec 8, 2008 | 03:52 AM
scooper's Avatar
Power washing is fine, I do it all the time, however I normally put something over the top of the carb and the distriutor and coil itself when I do it just to prevent such a thing from happening.
Old Dec 8, 2008 | 05:49 AM
axle09's Avatar
You havent messed with the timeing or anything have you? new spark plug wires? Plugs? Just asking to see if you have replaced anything. I have crossed plug wires before. But if you have water in your engine, not just in your carb or cap then run the truck for a period of time and see if it doesnt help. You may want to open it up a little too and let some new gas come into the carb.
Old Dec 8, 2008 | 12:38 PM
Scooby098's Avatar
yah I think I will but I bought a redline snorkel kit for the carb so figured I was safe, cause ive had a wet airfilter before and it would stumble at low speeds but smooth out, Im gonna take out all the plugs and replace them. I havent messed with the times I did kinda mess with the mixture on the carb to lean it out to see if that would keep it running but it didnt work. and I took all spark plug wires off and squirted some wd 40 in them to clean out what ever water there was.
Old Dec 8, 2008 | 07:21 PM
Scooby098's Avatar
K new spark plugs, and new plug wires and still no go, going to try a new ignitor tommomrw. and if that fails claim defeat and take it to a mechanic.
Old Dec 8, 2008 | 07:50 PM
celica-fiend's Avatar
Replaced the cap with the wires and plugs? Ive seen carbon tracking in a cracked cap cause misfiring/crossfiring..
vacuum leak around the carb? lean mixture causes backfiring out the carb.. check around the base of the carb, try and hear any air goin in..
You know the firing order is 1,3,4,2 right?.. so #1 is marked on the cap, and then clockwise the wires should go to 3,4,2 next..?
Brett
Old Dec 8, 2008 | 08:55 PM
Scooby098's Avatar
k Ill go get a new cap and rotor, it looks fine but its a cheap part to get it. Ill be sure to check to see if any the carb bolts have wondered loose too,
Old Dec 9, 2008 | 10:46 AM
small town BIG TOYS's Avatar
Brett
I wish I knew this 1 hour ago.
Old Dec 9, 2008 | 07:18 PM
check to be sure you havent any uncap'd vacuum ports sitting around too.. could be the pressure washer knocked one or two off, allowing a vac leak and lean running..
Brett
Old Dec 10, 2008 | 06:18 AM
Scooby098's Avatar
well after 4 hours of fiddleing with it, I came to this conclusion. its the carb not getting a steady ammount of fuel , new electric fuel pump so its not that new fuel filters not that. its the pressure device on the carb with the spring that regulates something mechianc told me, that if a strong backfire happens aka when it first got wet it can knock it out and I would need to rebuild it, 30 bucks for the rebuild kit or try and swing for a new carb a true weber instead of a 34 34. anything I should know before I attempt this?
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Poncho0206
Jul 10, 2015 06:21 PM
cyclist231
Jul 7, 2015 12:56 PM
