doug thorley header install
Ok so I just put my DT header on and looking back there is a copper o ring that was with the kit is this needed or what, this header eliminated the air injection and the oxygen sensor so I guess I'm just nervous but can someone tell me the proper way to install this header and I got new studs from Toyota and the nuts they gave me were stake nuts is that the right nut to have thanks
You do not state what size the copper "O" ring is. If it is the same size as the header outlet then on some applications it is used there to give you a proper seal.
I do not have a DT header but I used SS header nuts / washers that I purchased from Totally Stainless, they are designed not to loosen. Make sure to torque all header bolts evenly and use a stock Toyota gasket not DT or any aftermarket because most of them leak.
It is about the size of a quarter round and how do I know what applications usr this like I stated above my truck had air injection and oxygen sensor and this header eliminated those so I really don't know so if my motor blows up I'll know why I guess anymore info would be very helpfull
Sep 4, 2015 09:27 AM
