Pre 84 Trucks 1st gen pickups
Dave's 82 Toy Post
Old Feb 27, 2008 | 09:22 PM
  #61
WSUWESTON's Avatar
More info on seat install
I have had several people asking for more information on my seat install, so I am adding some more pics and info. Let me know if there is anything else you guys need.
First I set tthe seats in the truck where I wanted them. I ended up needing to drill 2 new holes for the front bolts. It helps if you just trace the holes, then remove the seats to drill. For the rear flat bracket I used washers (temp till I make a steel spacer) to level the seat out. For the 60deg bracket I made a bracket by using a piece of 1/4x 1 1/4" steel. I cut it to length and used a torch to heat it up while I used a hammer to bend it to match the 60 deg angle. It helps if you have a vice. One important thing is to use something on the underside of the floor bolt through. That way the bolts don't just rip through the floor. I used a 5" piece of the 1/4" steel. A lot of my pictures are blurry because my batteries were dying that night. Let me know if you have any more questions.
Old Mar 12, 2008 | 07:32 PM
  #62
WSUWESTON's Avatar
Weber Update
So over the past couple weekends I have been trying to figure out why I am not getting fuel. I ended up tearing apart the whole system and found that my intake tube in the gas tank was plugged. I ended up using compressed air to get it out. The filter that goes on the end of the tube was still in good shape so I am not sure how it got plugged. I just ordered a replacement filter and gasket from the dealer, so hopefully I can put it all back together this weekend. I also ordered two of the nipple things so I can do the axle breathers. I will post some pics after I get it all back together.
Old Mar 14, 2008 | 07:23 PM
  #63
WSUWESTON's Avatar
Well my tank filter will not be in till Monday so I won't be able t put the fuel system back together untill next weekend I did luck out tonight and found a MC rear bumper on CL for a good deal. It is in really nice shape. Now I just have to get the stock bumper and a homemade hitch off the back. The bolts are really rusty.
Old Mar 15, 2008 | 12:22 AM
  #64
dropzone's Avatar
Fossilized
Good deal about the Marlin bumper, i love mine.
Old Mar 16, 2008 | 05:26 PM
  #65
WSUWESTON's Avatar
Well I got the home made hitch off. Wait till you see the pics of this thing, it weighs a ton. I can't get all the bumper bolts out. There just is not enough room and they are rusted too bad. I am going to pull the bed off and cut the damn bolts off. Plus then I can clean up the surface rust on the frame and repaint it. Sand down the bed and paint and bedline it too.
Old Mar 23, 2008 | 03:35 PM
  #66
WSUWESTON's Avatar
Here is the home made hitch I pulled off.
Old Mar 23, 2008 | 03:46 PM
  #67
camo31_10.50's Avatar
when u say u might sell your carb..did u mean ur weber...or your stocker..if its weber..then i might be interested in it..thanks
Old Mar 23, 2008 | 03:47 PM
  #68
WSUWESTON's Avatar
Here are some pics from when I installed the weber. Check out the crud in the EGR.
Old Mar 23, 2008 | 03:51 PM
  #69
WSUWESTON's Avatar
No, I am keeping the weber for now. I got it running pretty well now. I do have two stock carbs to get rid of though if anyone is interested.
Old Nov 10, 2008 | 08:46 PM
  #70
95yoda's Avatar
nice progress! are you going to use the hurculiner in the bed as well? if so what prep will it require? and how many coats?
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
jbandt
Aug 3, 2015 03:23 PM
yoterr
Jul 24, 2015 04:29 AM
kcaudill
Jul 20, 2015 12:06 PM
