Pre 84 Trucks 1st gen pickups
85 axle in a 83?
Old Nov 15, 2006 | 04:02 PM
HAVOC's Avatar
Question 85 axle in a 83?
I've heard that the '85 axles are preferred if one is doing a SAS.
Is it a good idea to swap in an axle from a '85? Are the 85 axles that much stronger? Will the ring/pinion swap over?
Old Nov 15, 2006 | 04:15 PM
fourwd1's Avatar
The 85 front axle just has a little more gussetting than the 84, and the 84 than the 83, etc. Otherwise they are all the same, and the diffs are all the same. You can get gussets to strengthen an older axle from vendors or DIY, a lot easier than swapping an 85 for an 83.
Old Nov 15, 2006 | 04:42 PM
HAVOC's Avatar
Well, that answered my question.
Thanks.
Old Nov 17, 2006 | 05:34 PM
fourwd1's Avatar
Anytime
Old Nov 17, 2006 | 11:52 PM
Kirby's Avatar
I'm not sure if the diffs are the same, my understanding is 83 and older run 4:11 gears while 84/85 run 4:10 gearing.
Kirby
Old Nov 18, 2006 | 02:54 AM
HAVOC's Avatar
I will check the gears to see what ratio they are and that they do infact match when I pickup the truck.
Old Nov 18, 2006 | 07:06 AM
Sonofmayhem's Avatar
well some 4runners and some trucks came with 4.56s or 4.88s and my 80 truck has 4.37s, diff is the same. but different gears. they are all 8in axles.
Old Nov 20, 2006 | 12:29 PM
fourwd1's Avatar
Kirby
That's true, there were different R&P tooth counts (around 1981), but it makes no difference, you can run a 4.10 and a 4.11 with no problems.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
