Pre 84 Trucks 1st gen pickups
1981 toyo pick Up 22r fuel issue
Old Mar 7, 2009 | 12:23 PM
1stgen18's Avatar
Hey guys havent been on here in a while but wanted to thank you guys and gals for all the help and I did try out the octane booster and it still didnt help, I actually picked up another yota 88 actually and swap the fuel tank and carb over and what not but I got confused with the vacum lines. I attach two pics of how my vacum line is set up in my truck, please let me know if I got it mixed up. =(
Attached Thumbnails 1981 toyo pick Up 22r fuel issue-103_0104.jpg   1981 toyo pick Up 22r fuel issue-103_0105.jpg
Old Mar 9, 2009 | 06:28 AM
83's Avatar
83
Are you saying you put the 88 tank & carb on your 81, or what? Get the vacuum diagram for both models.
Old Mar 9, 2009 | 01:54 PM
kev's Avatar
kev
Check your choke mechinism. If it is sticking shut, open the throttle first then make sure to open the top butterfly.I believe there is a vaccuum diaphram that operates the choke. Make sure the diaphram in in working order. Kev
Old Mar 10, 2009 | 05:37 AM
1stgen18's Avatar
yes I switch the carb and tank over but got confused how the vacum lines are set up with that upper diagram, the truck currently doesnt have any smog equipment on it
Old Apr 24, 2012 | 08:54 PM
  #25
DMOORE54's Avatar
Can anyone send me some good under hood pictures or the vacuum line routing for a 1981 toyota 4x4 with cal emissions primarily the right side of the carb and air filter connections my carb has the ac pulloff switch the hoses are numbered any help will be greatly appreciated .i love toyotas!
V/r d.m.
Old Apr 25, 2012 | 11:32 AM
  #26
kawazx636's Avatar
DMOORE, scope this site out:
http://www.ncttora.com/fsm/
The diagram that you are looking for is in the FSM. I personally use the 1985 FSM which is pretty much the same for the 1st gen years for my 83 pickup.
Old Apr 25, 2012 | 01:27 PM
  #27
Terrys87's Avatar
I seen where you flushed lines, changed filters and so forth. Did you change the filter in the tank? Mine had a hard shell of varnish on the in tank filter. I may of missed your post but didnt see it when going thru your thread. There is a pic of it on my 83 build on page 7.
Part number for a new intank filter is #77023-12050. On ebay it is called a TOYOTA FACTORY NIB FUEL FILTER SUCTION TUBE DIESEL. It was selling for $4.50 when I finally found it. I paid $15 at Toyota.
Edited....Just seen this was an old thread, still I have found a few that didnt know there was a filter in these tanks.
Old Apr 25, 2012 | 07:01 PM
  #28
DMOORE54's Avatar
Thanks for the info v/r d.m.
Old Apr 26, 2012 | 06:39 AM
  #29
83pingpong's Avatar
Thumbs up Lots of useful stuff here, Thanks
When the new coil does not fix my stalling issue later this week (#!#@!*!), I will probably dig into the fuel system. I may be getting a vapor lock due to some blockage. It feels electrical -shuts off like a switch, after it warms up. It seems like it could be the coil, since I've replaced everything else in the ignition system except the key/ignition switch!
But the first thing I checked/replaced was the fuel filter outside of the tank, and fuel was freely spilling while I changed it. If there is blockage, it may be farther forward in the lines.
At 230k miles, and nearly 30 years, the fuel system is probably in need of cleaning.
I never would have suspected there's a filter at the fuel pickup in the tank!
Thanks!!
Old Sep 3, 2012 | 09:05 AM
  #30
latern88's Avatar
toyota carb switch
i have an 83 toyota 4x4 pickup and i am switching the carb from stock to a weber but im having issues figuring out what one to get. theres a few. the one on the truck is electric choke. i dont mind having a man choke but theres also the issue of cc of the motor. how do i figure out that. the number on the carb tag is 35291. it appears that a few of the weber carbs will work but i dont what to get the wrong one. help anyone on any of these questions please.
Old Sep 4, 2013 | 08:36 PM
  #31
Logan1985yota's Avatar
My truck kinda does the same surging thing. It is an 85' 22r and I have noticed that the gas tank builds up an enormous amount of pressure when the engine is not in use. I was wondering if pressure could cause a problem with the fuel system? And if I might need a new gas cap?
Old Sep 5, 2013 | 07:51 AM
  #32
enigmaT120's Avatar
If I were shopping for a Weber (my truck came with one) I would call these guys:
http://www.lceperformance.com/Carburetion-s/134.htm
They will actually talk with you, and know what they're talking about. There's also a forum discount, I don't remember how to get it though. Check out Kaw's desmog thread for more details.
Old Dec 18, 2014 | 06:40 PM
  #33
grkustoms's Avatar
gas line being pinched
The gas line was pinched between the tank and fuel filter under the bed on my buddys truck after changing the fuel filter keeping it from from running at higher rpm but it was good cause we cleaned carb and grounds and it is idleing and running better then ever now and revs high rpms great
Old Jul 12, 2018 | 09:28 AM
  #34
Brent Andrew Davis's Avatar
I had this problem last night like it was bogging down or misfiring and it turns out that it got vapor locked due to the gas cap being ttoo tight. I took the cap off and put it back on just snug. No problems after.
Old Aug 19, 2019 | 05:18 AM
  #35
bpolk's Avatar
Was having a similar issue after I found a black plastic cap under the vehicle. Turns out the cap went on the EGR Vacuum Modulator. Cleaned the filter, put the cap back on, and all is well...for now. Still need to rebuild carb, and have fuel tank cleaned and sealed (38 years and counting!).
Derek79
Nov 12, 2016 08:51 PM
Brian1973
Dec 12, 2014 09:18 AM
Hook
Mar 17, 2012 12:55 PM
slacker
Oct 25, 2011 04:07 PM
916yota
May 5, 2009 07:39 PM
