Pre 84 Trucks 1st gen pickups
1980 Pickup 4x4 22r not making power.
Old Jun 27, 2021 | 08:56 PM
OwenYota's Avatar
What else can I say. New Alternator (tested and works), new IC Regulator, new battery. The excitement wire is getting power and gives power to the alternator, but still seems to not be turning on and charging. I know that there are three wires coming off of the alternator (yellow, green, and white/black). I think I’m good on grounds, the main ones seem to be connected pretty well. Any advice would be nice.
Old Jun 28, 2021 | 06:37 PM
1stgenboy's Avatar
Are you saying your getting nothing out of the alternator at all?
Old Jun 28, 2021 | 06:58 PM
OwenYota's Avatar
Well, yes. The Alternator isn’t powering the motor (engine dies when battery is disconnected). I am trying to find the fuseable link to the alternator right now but can’t seem to locate it. Even then, why would it matter? Battery volts measure 12.6 and then battery to alternator also measures 12.6… I think there’s something wrong with the three wires that come off of the alternator. Maybe the alternator doesn’t know it’s supposed to be charging? I have no idea anymore.
Old Jun 29, 2021 | 12:18 PM
2ToyGuy's Avatar
The engine will always die when you disconnect the battery. The battery provides the excitation voltage to the alternator, among other things. You pull the battery, you open the entire circuit, the alternator and/or battery, doesn't provide any power to the system at all, no power, no spark, ignition, ECU, fuel pump, nothing. That's why the truck dies. The battery is an integral part of the entire power system. Take a terminal off the battery, the entire power system fails.
If the alternator has battery voltage at the alternator's terminal B, the alternator isn't charging the battery. Alternator, or the wire from terminal B to the battery, is bad. The plug on the back of the alternator should indeed have battery voltage on the two white wires. One tells the alternator the battery voltage, and how "hard" it should charge the battery. The lower the battery voltage, the greater the voltage on Terminal B should be to compensate. Since the terminal B wire should go direct to the battery + terminal, the voltage should be much higher than regular battery voltage with the truck running.
Is that any help?
Pat☺
See my other post to your thread for more information.
OwenYota
11
Mar 9, 2022 04:27 PM
87yoda87
Nov 17, 2013 06:44 PM
Toyomo
Feb 10, 2010 12:38 PM
yota7357
Aug 18, 2009 03:34 PM
82greenbeast
May 31, 2008 10:13 AM
