Pre 84 Trucks 1st gen pickups
Identify this washer
Old Jun 30, 2021 | 08:54 PM
jjswenn's Avatar
5 Year Member
Thrust washer slight play
Hey YT,
I dropped the oil pan tonight on my 22r (unknown year engine installed in an 81 longbed 4x4) to remove the crappy cork/rubber pan gasket (its had a very slight leak) the PO installed when rebuilt. I’ll be using FIPG when reinstalling the pan, NO GASKET. Anyway, I noticed the front thrust washer had some slight play in it while poking around under there. The one facing rear is solid (see image pointing at front thrust washer with screwdriver tip). I’m thinking of checking the torque on all the bearing caps tomorrow and/or popping that one main bearing cap off and checking it out further. I’ve installed a number of these 22r’s over the years, but actually never disassembled/assembled/rebuilt one completely myself. Maybe it’s time I give it a go.. How doomed is this engine? It runs like a top now, but only had about 1500 miles on a rebuild by PO. Thanks
Old Jul 3, 2021 | 07:29 AM
slacker's Avatar
there should be some movement in the crank , thrust washer clearance max is .012
standard clearance is 0.0008 - 0.0087
1st Gen Crawler
Jan 13, 2015 03:19 PM
linuxrunner
Jul 31, 2014 06:14 AM
element138
Nov 3, 2012 10:12 AM
Sr5trd99
Aug 14, 2006 03:47 PM
Localmotion
Mar 22, 2006 06:30 PM
