1979 Toyota pickup electric fuel pump question
I recently picked up a 79 Toyota 4x4 20r it has been sitting for quite sometime and I am trying to get it running. I am able to keep it running by manually pouring fuel in the carb. So I figured it’s gotta be the pump I noticed where the factory mechanical pump would be there is a block off plate. So I figured they wired up a electric but I can’t find it under the truck is it common that when you do the conversion you put the pump in the tank? Everyone that I have seen they mount it under the truck on the frame rail
