Pre 84 Trucks 1st gen pickups
1979 Toyota pickup electric fuel pump question
Old May 29, 2020 | 04:38 PM
Joelshane's Avatar
I recently picked up a 79 Toyota 4x4 20r it has been sitting for quite sometime and I am trying to get it running. I am able to keep it running by manually pouring fuel in the carb. So I figured it’s gotta be the pump I noticed where the factory mechanical pump would be there is a block off plate. So I figured they wired up a electric but I can’t find it under the truck is it common that when you do the conversion you put the pump in the tank? Everyone that I have seen they mount it under the truck on the frame rail
Old May 29, 2020 | 04:54 PM
millball's Avatar
I'm sure that someone more knowledgeable will speak up, but some of these early carb engine trucks were factory equipped with electric pumps.
Old May 29, 2020 | 05:06 PM
Joelshane's Avatar
Yeah man I’m confused I swear my 1980 had a mech pump super weird that they would switch to a mechanical pump after having an electric.
Old May 29, 2020 | 05:09 PM
millball's Avatar
Yeah, but they did.
Old May 29, 2020 | 06:32 PM
scottd's Avatar
I think most if not all '79's came with an electric fuel pump in the gas tank from the factory. That is the case for my '79. I think Toyota switched to the mechanical pump in '80.
Old May 29, 2020 | 07:12 PM
Joelshane's Avatar
Awesome thanks for the replies guys. Does anyone know if there is a fuel pump relay anywhere? I checked all over the rig and online and I didn’t seem to find one
Old May 29, 2020 | 07:18 PM
scottd's Avatar
Yes it's under the dash on the driver's side. It's a little hard to see.
greaseball
Nov 16, 2013 11:01 PM
monoxide_85
Sep 11, 2011 04:03 PM
FUNrunner87
Aug 3, 2011 10:45 AM
smallenginemechanic
Feb 8, 2010 07:22 PM
komh98
May 3, 2009 06:18 PM
