Frontier 4x4's "83" Toyota buggy
$10k, located in Chariton Iowa
641-862-3712 - Luke - luke@frontier4x4.com
VERY detailed build thread -
http://www.pirate4x4.com/forum/toyota-truck-4runner/699664-frontier-4x4s-83-toyota-build-6.html
1983 Toyota SR5 - Tube is 1.75x.120 DOM
Clean title
I still drive this down the highway, handles great.
New 22RE - Just broke in, 3 days of wheeling
RV Cam
K&N filter and prefilter
Trail-Gear header
Flowmaster 40 muffler
New radiator
New GM 94 amp alternator and wiring
W56 Trans
Ceramic Clutch
Dual T-case 2.28/2.28
Trail-Gear twin sticks
Trail-Gear rear disconnect
ARB compressor
3 Trail-Gear long slip drivelines, equal length .250 wall tubing
4.10 gears
Detroit locker front
Welded rear
Dirty 30 birfields
Trail-Gear high steer
Trail-Gear HD inner seals
Trail-Gear wiper seals/rock rings
New wheel bearings
Vented rotors
IFS calipers
1" master cylinder
Wilwood prob valve
Trail-Gear rear disc brake kit
Trail-Gear drive flanges
Trail-Gear 3" front springs
Fox 12" remote res emulsion shocks
Trail-Gear rear 4-link
Fox 14" remote res coilovers
PAC springs
5 - 36" TSL
5 - 16x8" steel beadlocks
Corbeau low back w/ headrests
Corbeau 2" 3 point harness
Corbeau Safari rear bench
Chassis Unlimited seat sliders
Crawl Tunes 6.5" speaker enclosures
JBL amp
Trail-Gear stripper lights
Artec Quart Crate
Jaz Fuel Cell
Artec fuel cell mounts
Walbro fuel pump
Trickflow filter
3 shut off valves
rear line lock
Warn M8000
Optima Red Top
Trail-Gear battery mount
Hi-Lift Jack
Everything works great, ready to wheel. Getting ready for another event so it will all be cleaned up and new skins. Also a few more parts
and work that I will list when done.
Clean title
RV Cam
Trail-Gear header
New radiator
W56 Trans
Ceramic Clutch
ARB compressor
4.10 gears
Welded rear
Dirty 30 birfields
New wheel bearings
Vented rotors
IFS calipers
1" master cylinder
Wilwood prob valve
PAC springs
5 - 36" TSL
JBL amp
Artec Quart Crate
Jaz Fuel Cell
Walbro fuel pump
Trickflow filter
3 shut off valves
rear line lock
Warn M8000
Optima Red Top
Hi-Lift Jack
Lots of new stuff completed, all updated in the build thread. Wheeled last weekend and everything is working great.
Added:
synthetic winch line
aluminum fairlead
7.5" LED light bar for reverse light
gain control for amp
CB in dash
LED center console light
LED under dash light
moved speakers
painted roof
fresh tube paint
more stickas
Added:
aluminum fairlead
CB in dash
moved speakers
painted roof
fresh tube paint
more stickas
