Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
welding tips
Old Sep 15, 2006 | 09:15 PM
jjrgr21's Avatar
is there a welder that i will be able to use a standard plug, not a 220 range plug, if so how many amps will it need to handle. is there an arc welder that will do this.
Old Sep 16, 2006 | 06:27 AM
Flygtenstein's Avatar
If you are going to buy a welder, get the best you can afford reasonably.
I find MIG to be easiest, then oxy fuel, then stick then TIG.
Practice. You need to see what something looks like when it is good.
I find it easier to welder better with a bigger machine. You can put in enough heat and get penetration. Not a fan of those little 110 machines.
I always wear tall boots so sparks don't get down into them.
OCC tacks with their eyes closed. I hate grabbing a mask to tack.
Get good stuff and practice.
Old Sep 20, 2006 | 08:53 PM
4Crawler's Avatar
Best bet is to find a local welding class and take it. You'll get to try all the different types of welders and find what works best for you. The class I took cost about $120/semester and was well worth it. If you figured the cost of all the scrap metal and welding consumables we burned through each night, it was a very inexpensive way to learn.
Old Sep 29, 2006 | 06:32 PM
jjrgr21's Avatar
BIG THANKS TO ALL!! i just finished my sliders, painted and mounted, i borrowed a wire-feed welder, and practiced. i wouldn't say my weld's are decent, but they work. just wanted to say thanks to everyone who gave me advice.
THANKS,
Jason
front bumper is next i think
i like welding
JonG85
Jan 18, 2023 04:31 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
runnermedic
13
Sep 21, 2015 05:20 PM
