Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Jack Stand Size
Old Dec 17, 2009 | 06:08 AM
Fo-runna's Avatar
Jack Stand Size
What size jack stand would you all recommend for a 98' 4runner with OME and 33's? I was considering these at 23 7/8" max height:
http://www.northerntool.com/webapp/w...4821_200304821
Not sure if they are tall enough though. I know I could measure but I'm at work right now so I figured I'd get the experts advice.
Thanks
Old Dec 17, 2009 | 06:57 AM
Fo-runna's Avatar
For clarity, I'm looking to have jack stands on the frame and have enough height to have tires off the ground.
Old Dec 17, 2009 | 06:58 AM
4Crawler's Avatar
That is about what I use on my '85:
- http://www.harborfreight.com/cpi/cta...emnumber=38847
For a little extra height, I made up a base out of 2x4s to give another 3" or so of lift:
And no, I can't keep the tires off the ground with the jack stands, but what I do is put a floor jack under the axle, raise it up enough to put in the stands, then I remove the wheels and lower the jack down until the weight is resting on the stands. Since my static frame height is about 23.5" off the ground, I can almost put the jack stands in place with the tires on.
Old Dec 17, 2009 | 08:21 AM
Fo-runna's Avatar
How much suspension lift were you running there? I'm assuming you have quite a bit more droop which would result in the need for taller stands than what I would need.
They also have some 30" stands for like $20 more... hmm.
I might just have to measure tonight and hold off on my order.
Old Dec 17, 2009 | 08:32 AM
4Crawler's Avatar
Probably 4" or so of suspension lift.
Old Dec 17, 2009 | 08:56 AM
Fo-runna's Avatar
I'm thinking the 24" stand isn't going to cut it.
Old Dec 17, 2009 | 09:18 AM
BigBluePile's Avatar
I have three sets of stands for depending on what I need. Small, medium and large lol! I too, have to take tires off to use jackstands but only if I'm doing axle work where I need the springs to be at full droop. Other than that a medium set of stands under the axle will work just fine. I got mine thru Harbor Freight.
Old Dec 17, 2009 | 09:43 AM
waskillywabbit's Avatar
HF 12 ton jack stands are like 30" tall. I have 8 pair and then some 6 ton and 3 ton. They are beef and painted orange you don't misplace them.
Old Dec 17, 2009 | 11:31 AM
Elton's Avatar
i just got some basic 3ton ones works fine with my 33s
Old Dec 17, 2009 | 01:56 PM
hross14's Avatar
The bad thing about the larger jackstands is that they take up more floor space--and that stinks when you are working under the truck??IDK
I use the HF deals with 3" Wood spacer as pictured above
Old Dec 18, 2009 | 05:15 AM
Fo-runna's Avatar
Wabbit are those 30" stands enough to keep the tires off the ground on a 98' Runner with OME 881/891 & 33's when the stands are under the frame?
Old Dec 18, 2009 | 05:49 AM
Tape measure frame to ground under d side door and u tell me.
Old Dec 18, 2009 | 06:14 AM
Fo-runna's Avatar
I know, I'm such a slacker...
Old Dec 18, 2009 | 07:53 AM
DeathCougar's Avatar
I use those 6 ton stands on my Dodge, and the lift the tires off the ground just fine.
They also work well on MR2's, where we have to lift the back end of the car up to get the engine out
Old Dec 18, 2009 | 08:22 AM
Jack stands? I just pay someone to work on mine...
oldblue
Sep 28, 2015 04:07 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
