Testing my 32" Roughrider AT's
Trying out new AT's
All this mud was only in 2wheel. Yes it was on lte side of a farmers lane, but the mud in the ditch was good and thick....
Hey, do those 32-inchers rub in the front at all? I have my t-bars cranked about half a turn more from the factory plus heaver duty springs in the back (about a 1.5 lift all around, I figure). I just might be able to run those 32 when Cdn Tire has a special on them.
I have no rubbing at all except on the bent up front valance (which all I need to do is either remove it or replace it. I figure I can probably run 33's without rubbing (at all or too much) My truck is stock, so I guess I'll see next time I need new tires....
I dont know how you people arent rubbing at all with 32's on stock ride height... I have 32x11.50r15's on my truck and i had to trim the rear of the front fender well, and with the tires completely cranked, when i flex the truck out it still rubs sometimes. It isnt bad it is just a little bit on the plastic lining, but it does rub... Also, they fill the wells really well...
See...
See...
4 Runners must have a bit more clearance.... Like I said the only rubbing I have is at that bent front valance.... Here are a few more pictures showing clearance.....
There is 13.5" from rim to fender in the front, and 10.5" in the rear....
Now I need to take care of my saggy ass syndrome....
Originally Posted by 92' 4Runner SR5
Those are 2 different brands of tires and most likely 2 different sizes although both are " 32" tires"
Originally Posted by MorphiasX
Very true, that is actually probably the reason why mine rub and yours dont. My BFG's are probably bigger, eventhough they are both 32's. And i dont think that the 4runner has bigger wells, they are the same exact fender from the truck to the 4runner.
I'm running BFG MT 32's and they rub slightly on the front valance on full turns and thats with OME suspension and my t-bars slight crancked up
How those things treaten you is the one still holding air
Originally Posted by 4rnr
loose the valence
Yeah, the one is still holding air. I'm going to trim that plug up some more. I'd hate to rip that thing off in the trails.
accuracy
Sep 20, 2015 07:44 PM
Boomer8404
Sep 20, 2015 06:15 PM
