Moab Recon
Moab Recon
Well folks, we just got back from spending a couple of days in the HOT Moab sun. I have published a few pics on my site, if you're interested.
We ran the combo trail: Poison Spider - Golden Spike - Gold Bar Rim in just a little over 6 hours. A failing spring bushing really slowed us down at the end.
We also ran Fins and Things, which was pretty cool. Be sure you have your gear tied down! There are a lot of very steep ups and downs when you are climbing the fins and dropping off them. We did this one in about 2.5 hours. Pretty easy stuff.
and by they way, in these shots you can get a glimpse of a partially finished new front tube bumper I'm working on. ABQJim was gracious enough to lend me his winch as a backup when touring these trials. This new bumper will hold the 8k or 9k winch nice and tight against the front grill. Actually, if you look real close, you can see how the front grill was notched to allow the winch to sit up higher.
Its a work in progress, but when its done, It'll be really strong and very tight!
Here is the link for the latest Moab trip.
http://www.hunt4steve.com/excursions...t_augrecon.htm
Originally Posted by 4Hummer
Sweeeeeeeeeeeeeeeeeet !!
Are those Leaf springs in the back of your Runner ?
Nice pics rig Steve. Wish I was there.
Question: I'm curious if your rig is a bit on the tippy side at that altitude. Looks like a long travel kit for the front and a wider axle in the rear are in order.
Originally Posted by SteveO
Indeed, it can get a bit tippy, as did happen this past trip. We almost rolled it with both of us in the rig. However, we kept the rubber down at nearly 40 degrees. Both of us were sucking up to the leather seats. The right front tire dropped off a ledge and the entire rig quickly pitched to the right, at which point, we both froze and held our breath for a moment. The right front tire was on the ground, so I drove it on through, but definitly a scary deal. Again, nearly 40 degrees, and it didn't roll, so I would say, its pretty stable. Indeed, I would enjoy a wider stance, and maybe one day in the future, after a roll-over, I'll have the dough to put in a wider stance.
tippy
Flygt, we did the trip to recon a couple of trails for the Oct Moab trip.
Jim, If you were to take your rig, turn it counter clockwise so its facing the photographer, and put the driver's tire on the high ledge (where your front drivers side tire is coming off) and the passenger tire on the low ledge, this is how we were taking this line. It was definitly not a good line, and a bit scary. The rig was leaning big time towards the passenger side, pretty scary. We wouldn't have rolled too far, but I'm sure it would have been a total....
and then I would tube it out!
Thanks Adrian for not letting me roll here!
About 100 feet up the hill from there is another place to easily mess up and drop a tire in a hole. Here's a pic from 3 years ago that shows that spot. You have to hug the tree to avoid the hole.
Jeff
Jeff
TheBFA
Feb 15, 2020 06:55 AM
skoti89
Jul 6, 2015 07:45 PM
Jeff the marmot
7
Sep 20, 2005 07:05 PM
Blair
Apr 26, 2003 01:32 PM
oops, I should read what I type...
