Building Homemade LongTravel?
Ive heard from alot of the older guys i know, that when they were my age they used 2 make their own suspension kits for their trucks. is there any guidelines or instructions for you to follow when making a long travel suspension for the front of a 94 pickup 2wd?
first of all why would you want to long arm a 2wd?? the time and effort put into that just is not worth it for a 2wd.. but no there is basically no rules or guide lines juxt geometry in check
For looks i guess. I like how they look and i was thinking about doing it to my truck but im not sure if i want to attempt it. and because the kit thats on there right now is not very safe.
well if you just like the looks are you prepaired to pay the price of coil overs? and 208 yes while most prerunners are are 2wd they have a leaf spring suspension in the rear so he would need to redesign his whole rear end lay out not to mention get longer brake lines to reach ( not to discourage you ) just take your time and all look at several jeeps that have them to wrap your head around what you will need as building one may not be exactly cheap if you dont properly plan...... your best bet to get a long travel front end is to get longer controll arms i guess
Last edited by racerflea; 01-28-2010 at 02:19 PM. Reason: my bad its for your front
What you said would be done on ANY vehicle that gets lifted.
@OP: Better have good welding skills, and be very math inclined, and have access to some good tools.
i think that would be bad ass...ive been kickin around the idea of building a pre-runner...go for it man...you dont learn unless you try!!! build, break build, and learn...bein on here helps too!!!
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
Gives some lift and some extra travel for not a lot of cost or effort. In back, you can do longer spring shackles or an add-a-leaf or for more lift, put the springs on top of the axle (weld on new spring perches), gives 4"+ of lift.
You can "long arm" a 2wd and get anywhere from 10-15" of travel, read up at the desert racing sites and research. Careful about asking stupid questions there like "how can I make a 20" travel long travel kit?". Use the search button and read lots before thinking about posting. Most guys suggest reading some books, I can't remember the name off the top of my head but search on those sites and you can find out easily.
Also check out Batch Racing, I think they are a newer company that offer kits quite a bit cheaper but you gotta source a few things yourself like uniballs and heims.
dezert rangers is definitely the place to go. most LT trucks are 2wd. the rear isn't really a problem...there's several options to choose from. the front is a different story...some people build their own, but if you don't know what you're doing you'll get yourself (and maybe someone else) killed that way. blazeland's kit isn't for 2wd last time i checked. I'd recommend checking race-dezert.com and dezert rangers for a used kit. you'll be happier getting a tried and tested manufactured kit than spending a ton of money and time fabbing one that'll probably break on you anyways. just my opinion
LittleUgly
15
01-02-2020 01:30 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
