Building Homemade LongTravel?
Old Jan 26, 2010 | 03:31 PM
RiseAgainst7580's Avatar
Ive heard from alot of the older guys i know, that when they were my age they used 2 make their own suspension kits for their trucks. is there any guidelines or instructions for you to follow when making a long travel suspension for the front of a 94 pickup 2wd?
Old Jan 26, 2010 | 04:45 PM
racerflea's Avatar
first of all why would you want to long arm a 2wd?? the time and effort put into that just is not worth it for a 2wd.. but no there is basically no rules or guide lines juxt geometry in check
Old Jan 26, 2010 | 05:04 PM
For looks i guess. I like how they look and i was thinking about doing it to my truck but im not sure if i want to attempt it. and because the kit thats on there right now is not very safe.
Old Jan 27, 2010 | 09:02 PM
Gnargoyle(208)'s Avatar
racer, most pre runners are 2wd.
Blazeland makes a "cheaper" lt kit.
or check out total chaos.
or use the search button. on here or google it.
Old Jan 28, 2010 | 02:17 PM
racerflea's Avatar
well if you just like the looks are you prepaired to pay the price of coil overs? and 208 yes while most prerunners are are 2wd they have a leaf spring suspension in the rear so he would need to redesign his whole rear end lay out not to mention get longer brake lines to reach ( not to discourage you ) just take your time and all look at several jeeps that have them to wrap your head around what you will need as building one may not be exactly cheap if you dont properly plan...... your best bet to get a long travel front end is to get longer controll arms i guess
Last edited by racerflea; Jan 28, 2010 at 02:19 PM. Reason: my bad its for your front
Old Jan 28, 2010 | 02:45 PM
as far as the rear goes. just buy some chevy 63 leaves. run bilstien 5100 shocks front and rear. thats all i plan to do
Old Feb 1, 2010 | 09:35 PM
peow130's Avatar
Uhhhhh
What you said would be done on ANY vehicle that gets lifted.
@OP: Better have good welding skills, and be very math inclined, and have access to some good tools.
Old Feb 1, 2010 | 10:11 PM
and dont do a spindle lift. unless you want a parking lot princess truck.
Old Feb 12, 2010 | 05:54 AM
ChickN's Avatar
i think that would be bad ass...ive been kickin around the idea of building a pre-runner...go for it man...you dont learn unless you try!!! build, break build, and learn...bein on here helps too!!!
Old Feb 12, 2010 | 06:30 AM
4Crawler's Avatar
For a lower cost option, you can put ball joint spacers on a 2WD:
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
Gives some lift and some extra travel for not a lot of cost or effort. In back, you can do longer spring shackles or an add-a-leaf or for more lift, put the springs on top of the axle (weld on new spring perches), gives 4"+ of lift.
Old Mar 27, 2010 | 10:55 PM
ckblum's Avatar
No offense but this guy has no idea what he's talking about. Not trying to be a dink but why do you go off about Jeeps when he's talking about IFS long travel? I think you are thinking of trailing arms on a solid axle.
You can "long arm" a 2wd and get anywhere from 10-15" of travel, read up at the desert racing sites and research. Careful about asking stupid questions there like "how can I make a 20" travel long travel kit?". Use the search button and read lots before thinking about posting. Most guys suggest reading some books, I can't remember the name off the top of my head but search on those sites and you can find out easily.
Also check out Batch Racing, I think they are a newer company that offer kits quite a bit cheaper but you gotta source a few things yourself like uniballs and heims.
Old Apr 3, 2010 | 08:39 PM
SnowRunner98's Avatar
Dezertrangers.com
might be better off getting a bolt on kit from TC. alot of work goes into a front kit like that. 63's or a deaver pack for the rear.
Old Apr 3, 2010 | 08:49 PM
rhill's Avatar
Originally Posted by SnowRunner98
Dezertrangers.com
dezert rangers is definitely the place to go. most LT trucks are 2wd. the rear isn't really a problem...there's several options to choose from. the front is a different story...some people build their own, but if you don't know what you're doing you'll get yourself (and maybe someone else) killed that way. blazeland's kit isn't for 2wd last time i checked. I'd recommend checking race-dezert.com and dezert rangers for a used kit. you'll be happier getting a tried and tested manufactured kit than spending a ton of money and time fabbing one that'll probably break on you anyways. just my opinion
LittleUgly
15
Jan 2, 2020 01:30 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
