!!Attn! Jeep Owner Needs Your Help!!
Ok. I need a new axle to replace the weak Dana 35 in the rear. I'm going to 35's and perhaps a V8, and she dont play ball for that action. I could drop a grand and go a couple of routes, but then I though - what about the rear axle of my hydrolocked 87 4runner. Its sitting under a tarp in the back yard, the V8 swap never came to fruitation since the purchase of my jeep. How strong is it? My buddy is running 36's and a chevy 350, with no reported problems. You guys have the coolest smilies
The 8" Toyota axle is pretty strong, about the same as a Dana 44. You'll have to work out something to match the pinion flange to your driveshaft, and you may find only certain gear ratios match between a Toyota and your front axle (Dana I assume). Also, the axle is set up for spring over axle and you'll need to use 6 lug wheels in back.
Originally Posted by 82trekker
Well, your on the right track at least. Keep replacin' parts and you'll eventually have a toyota
Originally Posted by stjjames
Ha!!! Obviously I had one! Strong as a dana 44 huh? I have a Dana 30 in the front, I have 4.11 gears, which I believe are the same in my yota. Driveshaft may present a challenge, and finding bolt pattern adapters - well that shouldnt be that hard. Hmmmmnnnnn. coil perches, Im not sure how those will fit - but as long as I'm welding, it shouldnt be a problem. Guess I should have said this from the get go - 98' TJ, which means no leaf springs - all coils. Hmmmnnnn. . . I'm gonna go untarp that beast and take a look -
Yeah my buddy could cut & gut a ford 8.8 for me as well, same bolt pattern and I get disk brakes + a lsd, or whatever locker I want, well can afford . But since that 4runner isnt doing much. . .Man Toyotas rock, I hate the Dana 35, how strong are the front axles, on the solid axle toyotas? If I dont steal this axle I'll drag to my buddies house and drop in a 350, let my girlriend hit trees with it
Originally Posted by 4Crawler
You could also look at a '90-95 4Runner rear axle, they are coil sprung, but in all likelyhood, you'll have to torch off everything and add your own coil perches, suspension link brackets, etc.
35's w/ a dana 30 I would upgrade. Since you are already beefing up the rear, the front should match-strenght wise.
I had a dana 30 in my xj on 32's. it was fine for moderate wheelin', but that is why i sold it. too expensive to build the 30 right. get a 44
coryc85
12-05-2015 08:42 AM
runnermedic
13
09-21-2015 05:20 PM
meatballs
09-16-2015 06:25 PM
