Timing belt kit question
Old 02-27-2013, 05:45 PM
crazypaint's Avatar
Ok I'm picking up a used motor has 78k on it. What all should I do for the timing belt stuff. I know timing belt and water pump what else should be done thanks also oem or name a good aftermarket brand. Wanna be good for the next 100 k
Old 02-27-2013, 06:03 PM
rworegon's Avatar
https://www.yotatech.com/forums/f2/g...lt-kit-265796/
A 3.4l engine? If so, the kit in post 1 or 6 above (or AirCabinMans less expensive kit) will do the job. Also, pick-up a crank bolt from the local dealer as it's listed as a non-reusable part.
Post 1 here for a very good tutorial.
Old 02-27-2013, 06:10 PM
crazypaint's Avatar
Ya my bad 3.4 thanks
Old 02-27-2013, 06:12 PM
rworegon's Avatar
Welcome!
Old 02-27-2013, 07:42 PM
98SR54RUNNER's Avatar
How much is a motor with that low mileage costing you, if you don't mind me asking?
Also, here's FSM timing belt docs:
File Type: pdf
File Type: pdf
File Type: pdf
Old 02-28-2013, 01:34 PM
crazypaint's Avatar
I got lucky and found one on Craigslist for 550 I pick it up. O by the way I did use the search just so everyone knows. The motor was a steal
Old 03-02-2013, 12:44 PM
crazypaint's Avatar
Got the motor will post pics tonight
Old 03-06-2013, 09:16 AM
Renaud33's Avatar
Where are the pics??
Old 03-06-2013, 08:12 PM
crazypaint's Avatar
Lol damn motor swap started early I will try to post them soon I get ou of work then go work on it till midnightish I hope it's worth the motor change heap cause its a pia
Old 03-07-2013, 07:30 PM
crazypaint's Avatar
New motor
Old motor
Hole in old motor lol
Blew the oil filter and threaded nipple right off he'll of a mess getting the old motor out. I got the valve covers and intake cleaned up tonight and found some spray bomb silver looks better than they were. Had to switch out the exhaust manifolds and crosse over pipe. Apparently 99 and 02 are different. Will post more pics tomorrow
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 03-07-2013, 07:31 PM
crazypaint's Avatar
New motor
Old 03-07-2013, 07:32 PM
crazypaint's Avatar
Old motor
Hole in old motor
File Type: jpg
Old 03-07-2013, 07:33 PM
crazypaint's Avatar
Sorry iPad is going crazy
Old 03-07-2013, 07:34 PM
crazypaint's Avatar
For some reason my pics were messed up but ya get the idea ill try to straighten it out later
voiddweller
19
05-02-2016 09:10 PM
stagger_lee
03-29-2016 06:27 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Timing belt kit question
