96 4 Runner Rear Wiper
My rear wiper is not doing a good job on the top portion of the window. I have replaced the blade and still having problems. The wiper blade appears to be losing contact with the window in that area and I do understand why, nor do I see any way to adjust it. Any suggestions? Thanks!
This is a common problem with 4Runners. I believe the spring loses its.....spring.......which causes the contact problem. It's too cold right now, but once it warms up a bit, I am going to try to figure this out.
Bend it.
I had to do the same thing to mine.
Work the spring then bend it right where the arm and the blade attach ever so slightly.
Works perfect now, and I have had the same blade on there since 97 :-)
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
