DIRTCO's 1986 4Runner Build-Up Thread
Old Jan 18, 2009 | 02:38 PM
  #401
DIRTCO's Avatar
Originally Posted by vwfastg60
Looks like a sweet shifter...Cant wait to see it.
I can't wait to get it installed, along with the gear drive transfer case (I really just want to go wheeling). It should add a whole new level of control over the trans and transfer case.
Originally Posted by R.DesJardin
Great build thread, I'll look into the t-case shifter controller. My Toy has a top shift transfer case so any info on the t-case electronics would be helpful.
Keep up the good work.
Thanks, you make a great product. I can't wait to test it out!
I would try to get a hold of Hayes for info about the transfer case controller. I think he has some info on the wiring/electronics, I know it's like a mini auto transmission. I think it would be pretty easy to figure out.
Old Jan 18, 2009 | 03:22 PM
  #402
DIRTCO's Avatar
Originally Posted by grant526
I guess that is one way to fix the issue with the Factory Drain plug in the axle. I was TOTALLY SHOCKED this last summer. A couple buddies mine and I ran the Rubicon, with the Marlin Crawler Round Up group. I couldn't believe it when both of my buddies Ripped the drain plugs out of their axles! One the 1st day, the other the 2nd day. Fortunately I had brought 2 spares with me. One Low-Profile and the other my original stock. lol I believe both got used! But the second truck ruined the threads so bad that he was going to weld the plug in when he got home. Given the option, the way you did it was a much better idea!!
I've said it before and I'll say it again. You do GREAT Work!!!
Keep up the GREAT Work and the Updates!
Grant
That's exactly why I cut them out! I've seen this happen WAY too many times. When I first built the old green 4Runner I just welded the drain plugs in. It worked well but I didn't gain any clearance and I could still feel the plug grab on the rocks (until I wore it down a bunch). It makes draining the fluid a PITA, but really, how often to you replace the fluid. I replace mine once or twice a year, I figure that it's worth the extra work.
Thanks for the kind words, I'm glad that people are finding this thread usefull. I have learned tons from other build treads and write-ups, I figured that I should return the favor.
Old Jan 18, 2009 | 04:27 PM
  #403
DIRTCO's Avatar
I worked on the truck all day Saturday and got a decent amount of work done. I tore apart the front and rear axles to swap 3rd members, I also wanted to replace the front axle seals since one of them was leaking.
I started by draining the gear oil, it's really easy if you pull the 3rd member
I tore apart the passenger side (that was leaking) and this is what came out...
Gear oil + grease =
Then I tore apart the driver side ...
This is what I found, the grease looked like peanut butter or chocolate. I can't tell if this was from water coming in contact with the grease, heat or just normal discoloration?
Old Jan 18, 2009 | 04:45 PM
  #404
DIRTCO's Avatar
Front and rear axles apart
Lock Right 5:29 third, was in the front, now the back
Spooled 5:29 third, was in the back, now the front
Old Jan 19, 2009 | 04:47 AM
  #405
nosfanatic2006's Avatar
I love this build! Great work and great detail and great ideas and just plain great . I'm keeping my eye on it and can't wait to see it finished and wheeling.
But I was thinking a lockrite would be easier in the front than the spooled? Cause doesn't it kind of unlock, which would make steering easier? Oh well, I guess we'll find out how you like the setup
Old Jan 19, 2009 | 06:20 AM
  #406
ScottyC's Avatar
He has hydro assist.
Old Jan 19, 2009 | 06:30 AM
  #407
Junkers88's Avatar
And that right there is the only way to turn a spooled front end. I ran spools front and rear in an old scout for a while and with out the ram assist you couldn't turn that pig on pavement.
Old Jan 19, 2009 | 06:39 AM
  #408
Junkers88's Avatar
Originally Posted by DIRTCO
I thought it was the factory Turbo AFM, but after looking at yours I think it might be a Supra AFM. The little tabs off to the side look the same as the one you have. When you get time would you mind posting the part numbers on your AFM cover, mine has two sets of Toyota part numbers (one above the other). Thanks!
Man I'm sorry this took so long. There are indeed two sets of numbers. The top one is 22250-43110 and the bottom one is 197100-3020. It's from a 1982 Supra with the 5mge motor.
Old Jan 19, 2009 | 06:43 AM
  #409
Junkers88's Avatar
I got the rail shifter on Saturday, I just have not had time to take pictures. Overall I'm very pleased with the customer service and the product itself. The unit is smaller than I thought it was going to be, but it should work well with where I want to mount it.
And this is where I show you all how much of a noob I am....
Exactly what in the heck is this thing???
Old Jan 19, 2009 | 04:06 PM
  #410
DIRTCO's Avatar
Exactly, without the hydro assist I wouldn't be able to turn the thing. I had a hard enough time with the lockrite before I got the hydro assist. The lockrite hardly ever disengaged, let's just say that Hell's Revenge was a little rough.
One more thing to remember, my front axle is not stock. I have the 30 spline Longfields, LF 300m hub gears, ARP knuckle studs, LF 5th stud mod and some other stuff . A stock Toyota front axle would not like a spool very much!
Old Jan 19, 2009 | 04:18 PM
  #411
DIRTCO's Avatar
I don't even try to drive on pavement with the front hubs locked or in 4 wheel drive. Even in the winter I hardly ever use 4 wheel drive, the rear locker really does a good job of getting around. Also, most the easy /moderate trails I run in two low. It's a lot more comfortable and saves some wear on the front end.
Thanks for grabbing the part numbers, I'll have to check mine
That's the manual controller for the auto transmission. I'll have a switch that will let the computer drive (like normal) or let me shift when I want. I will also be able to have a true first gear without it shifting to second on me.
Old Jan 19, 2009 | 04:44 PM
  #412
DIRTCO's Avatar
On a side note, I always use the factory Toyota sealant (FIPG) P/N 00295-01281 on my third members and transfer cases. The stuff works great and doesn't smell like crap (like everything else out there).
I also tightened up my steering box. It had some play in the wheel and kind of wanted to wander around on the road. It only took 5 minutes (if that) and made a huge differance in how the steering feels. I can't believe I didn't do it sooner .
The adjuster is the screw head with the nut around it. Loosen the nut, tighten the screw and retighten the nut. That's about it.
Old Jan 22, 2009 | 05:37 PM
  #413
Hayes's Avatar
Where did you get that mount for your satellite radio?
Also, when you regeared your diffs, did the vibration you were getting at idle stop? I just got my diffs installed today and the idle vibration (the one that felt like the TC was unlocking) went away completely.
Old Jan 22, 2009 | 09:59 PM
  #414
Volcom's Avatar
Good question, I need something to hold my new GPS (it's my speedo )
Old Jan 22, 2009 | 10:14 PM
  #415
SpecialScottie's Avatar
Great pictures!
Please forgive me if this has already been answered, but is the only way to connect a toyota automatic to a gear driven case with the inchworm adapter?
Old Jan 23, 2009 | 04:43 AM
  #416
Hayes's Avatar
Originally Posted by SpecialScottie
Great pictures!
yup.
me reply is too short, please add more.
Old Jan 23, 2009 | 11:43 AM
  #417
jarboarder1's Avatar
WOW. I missed alot. I had no idea you scrapped your other runner until I saw you post up on the CO4rj thread. Sad to see it go, I loved that truck and got a lot of ideas for mine from it.
Anyways. This new one is bad ass. After carnage last year I wonder how long you can keep it clean
Old Jan 23, 2009 | 05:38 PM
  #418
DIRTCO's Avatar
The mount is a modified Sirius mount, the end used to have a suction cup. I removed the suction cup and found a piece of C channel that the bracket fits inside. It's really simple but sounds complex, I'll take some pictures tommorrow. That would work better.
Hayes, the vibration your talking about is when you are at a stop, in drive and the RPM's drop a bit. Right? The whole vehicle shakes and if you shift into neutral it's fine.
The vibration I was getting got a lot better before I did the SAS and gear swap. That's when I decided to keep the auto instead of swaping to a five speed. After the SAS it started acting up again (maybe two or three weeks later, and only for a couple days). Overall it has gotten a LOT better, but not gone away completly.
Old Jan 23, 2009 | 07:46 PM
  #419
DIRTCO's Avatar
Great pictures!
yup.
Yea, the Inchworm adapter is the only available option for the non-Tacoma auto trannys. There are a couple other companys that have made them, but they are not really available. The Inchworm set-up is really nice, I'll try to take some pictures of that too.
Old Jan 23, 2009 | 08:12 PM
  #420
DIRTCO's Avatar
I think I need to knock on wood after that comment!
Thanks! The last 4Runner was awesome, but not very practical with out a tow rig. After the last Carnage run, the truck was done. There was really no way to save it.
After a lot of thought, and looking at a bunch of rigs (including yours), I decided to build something more comfortable and well rounded. I'll be able to run most of my favorite trails (except Carnage ).
