OBD II Connector
OBD II Connector
So I'm finished with my swap, somewhat, but there is a Check Engine Light.
When I hook up a CAN OBDII machine to it, it doesn't read it. Says "no communication". I also try a Snap-On OBDII scanner, same thing. Says "no communication". I have read that some scanners can't read all vehicles. I'm hoping that's the case, that these two machines just can't read my ECM. But I just want to be sure (for the CA smog test).
So, on a 2000 Tacoma, what pinouts are supposed to be used on the OBDII connector? It's only four wires, right? I have an ORS harness, and haven't touched those wires.
I looked through my TIS downloads and can't find the reference to it.
On my wiring diagram for the ECU, the OBD2 connector is in a little box called "data link" or "data connection link" or something along those lines... I don't have it in front of me, otherwise I could tell you exactly. On my 1996, it was 4 wires. But I have heard that later years had more pins, and switched around wires, etc. So I would check into that. Also, 2 of the 4 wires on mine were grounds...which makes very little sense to my simple mind... If there is a ground terminal on the harness somewhere that isn't hooked up, that would do it too.
I found the "data link" on the diagrams and those look to be by the books. There isn't a section for just the OBDII connector to ECU diagram, right?
So on my diagram, the "Data Link Connector 3" on my 2000 Taco uses pins 4, 5, 7, and 16. But the OBDII ISO 9141-2/KWP2000 says pins 4, 5, 7, 15, and 16 must have metal contacts. According to mine, it is missing a 15. Is that okay?
Pin 4 is chassis ground
Pin 5 is signal ground
Pin 7 is the ISO 9141-2 K Line
Pin 15 is the ISO 9141-2 L Line
Pin 16 is the Battery Power
Does anyone know if both pins 7 and 15 MUST be used for the reader?
EDIT: Okay, I found that pin 15 (L Line) is optional, from the ISO 9141-2 standards. So ... now ... I ... must ... go ... check ... ing ... lines ... a ... gain. That sux.
Yeah, the unfortunate part is that mine does match up, but the scanners still don't read it. Not sure what else to do. Is there anything I need to do besides just plugging in the scanner?
I'm not sure. One of them is a CAN-OBDII reader, didn't catch the brand. The other one is a Snap-On OBDII reader. It's pretty neat, and you can see it switching the protocols trying to make a connection.
do you have the key on? right before the truck starts. make sure the pin locations are right for the year ECU you are using, how is the battery?
some drunk guy
08-03-2021 06:09 PM
mct75
08-22-2016 01:24 PM
