Highlander AWD AT Transfer Case
Old 07-01-2004, 09:10 PM
autodriver's Avatar
Does anyone know what type of fluid Highlander AWD Automatic use for its Transfer Case? Does the Transfer Case drain-and-refill separately?
autodriver is offline
Old 07-01-2004, 09:28 PM
superjoe83's Avatar
I'm not sure exactly how those are set up, but i would think that it uses ATF
superjoe83 is offline
Old 10-30-2004, 11:46 AM
Toytech's Avatar
It has a seperate fill and drain and uses gear lube. I think it 75-90w, but it says for sure on the fill plug.
Toytech is offline
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Phantez
09-30-2015 08:24 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Highlander AWD AT Transfer Case
