Little rust on the bed. POR15 no welding.
Hi. My bed has some rust. Yesterday I finally crawl underneath and there has been rusted out holes on the bottom of the bed that has rusted though. The whole bed has been rolled with nonskid (don't know the name, but like a navy ship). I can see the nonskid from underneath from the rust out missing piece.
I can't weld. My question is I have read really good stuff about POR15. I want to take of the bed and sand it down to metal and use POR15. I want to Redo the frame. Mostly the back end. The front end looks great.
Opinion please.
Other option is want to get a welder, learn and cut and weld, LOL. I want to keep the truck, forever ever.
Opinion please.
por 15 is good stuff....make sure to use thier metal ready first...wash then por15.
por15 fades with uv exposure (sun to you in the south) so top coat is advised
for sun exposed areas.
Cut the rust out to the good metal, sand down the metal around where you cut out the rust. If you are going to strip the whole bed use a chemical stripper. Clean the bed with a good degreaser, then with Marine Clean, then use Metal ready. POR 15 it all. Then cut pieces of sheet metal bigger than the holes. Shape to fit. Clean and POR15 the Patches. Pop rivet the patches over the holes. Use 3M seam sealer on the edges of the patches, Both sides, and over the rivets. It may not look the best, but will last for many more years. And just about anyone could do it.
Later
Later
Ok. So after reading some more about welding and stuff I have come to a plan. Understand my cars and truck are not my priority. I am active duty, drive 1.5 hours to and from base, a 9 month son and a second on the way, and a student part time becoming a RN.
Please put in your 2 cent. Not male RN are gay. Well because I'm not
I'm going to take a class on welding next semester and save up for a welder. I am looking to get a 110v. I don't have 240v but am thinking installing 240v in the basement and just running an extension outside. Cost less and doesn't violate city code when I sell the house. This is why I didn't bother to buy an air compressor for painting.
Engine wise I am keeping it stock. I'm a little interested in swapping a 1uzfe but too costly. Not adding a Weber, cams or header.
I want to get it in shape 1st. Its got a a cheap 3" from pro comp. Either way it looks nice.
Here are the pictures of the rust.
This is how most of the rust looks like. Mostly on the bed and back end of the truck. The cab looks great. If I was to repaint it to a different color it would be black.
This is what I am using to do my painting. Got it donated free with no gun
The new gun I just got. It's a Fuji.
I also wanted to learn how to weld also incase one day I wanted to put a marlin lift and do a 1uzfe swap.
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
1965chevy
09-20-2015 07:33 PM
