87 Toyota pickup radiator question
I have searched and could not find the answer. I am working on a 87 Toyota truck rebuild from the ground up. I have put a 3" body lift on it. The lift kit is a home made kit from 3"x3"x3" harden steel blocks. So my questions are as follows
1. Will the lift affect how the fan cools the radiator.
2. The radiator is from a 2 wd
will cause me problems.
Again if I missed this on the search sorry. The main purpose of this truck is hunting and driving in bad weather and very little extreme off driving.
I don't think this is the right place to post a tech question. try here.
https://www.yotatech.com/forums/f116/
You need to also lower the radiator about 3 inches..
When the engine torques it'll smash your fan blade into your radiator.
Or, the alternative is to get a drivetrain lift and smooth out under your body for more ground clearance.
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
