Sponsored by: CARiD
Transfer/Tranny ?
Old Jan 18, 2011 | 12:35 PM
richf's Avatar
Transfer/Tranny ?
I'm going to be pulling the transfer case this weekend to replace the rear out put seal, tranny out put seal and twin shifter and while I had some free time today I shot the bolts with some PB. I then noticed that when I take the transfer case out nothing is holding up the tranny. Do you guys put a 2x4 or something under there? A jack or jack stand? I was going to use the jack to lower the transfer case after reading it's a bit heavy/awkward with one person. I only have one jack that will reach the height I need. What do you guys suggest?
Also I don't understand the part were you have to apply the sealant to the new out put seal. Can some explain that. Do you need the sealant on the tranny out put seal also?
Old Jan 18, 2011 | 03:10 PM
yoterr's Avatar
yeah a jack stand would suffice...and ur motor mounts will love you lol as for the sealant i dunno...i actually have to do this to my rig...would be good knowledge
Old Jan 18, 2011 | 04:25 PM
MudHippy's Avatar
You put the sealant around the splines of the output shafts, after placing the companion flanges on them. Then you put the washers and nuts on. The bead of sealant seals the washers to the companion flanges.
See page TF-30 of the FSM: http://personal.utulsa.edu/~nathan-b...14assembly.pdf
Old Jan 18, 2011 | 04:40 PM
richf's Avatar
I think I understand now. I wasn't aware the the companion flange was splined. I had read some were on here that you actual put the grey rtv on the out put seal.
From what your saying, when you tighten everything down it seals it self up with the grey rtv.
Old Jan 18, 2011 | 05:02 PM
MudHippy's Avatar
From around the splines atleast. Grey RTV is fine. Toyota recommends their special red stuff, but I've used Ultra Grey, Ultra Copper, and regular high temp red on transmissions and transfer cases without any issues. There's some radial lip seals that seal the outer part of the companion flanges. You're supposed to wipe some MP grease on the lips of those before installing the flanges.
Old Jan 18, 2011 | 05:19 PM
richf's Avatar
When I connect the transfer case to the transmission. Do I need to use a gasket or can I use the RTV Ulta Grey?
Old Jan 19, 2011 | 12:51 PM
richf's Avatar
Alright I have everything unbolted. Can I pull this by myself? I have a jack under it to help support it.
Old Jan 19, 2011 | 01:01 PM
MudHippy's Avatar
Either or. Both will work. I've always used RTV, because that's what I have. If I had the gasket I'd probably use it, since it must have cost me something(and I'd have no other use for it).
I've never had anyone help me remove a transmission or a transmission/transfer case combo. But I'm not a scrawny weakling either.
Old Jan 19, 2011 | 02:44 PM
richf's Avatar
Thanks for the help. I pulled it no problem. Wasn't that heavy at all.
Old Jan 19, 2011 | 02:54 PM
MudHippy's Avatar
Yes. AFAIK. But I don't no anything about the twin stick installation. Does that reuse the old gasket, or did they give you a new one? It would probably be good enough to reuse the old gasket if it's still in good shape. But you might also dress it with some RTV too. Or if it's shot, you could use just RTV there also.
Old Jan 19, 2011 | 02:59 PM
richf's Avatar
are you referring to the gasket that's between the tranny and transfer? If so no it did not come with one. I plan to just use the grey RTV.
junkpile
Dec 16, 2013 07:38 PM
Dave M
Nov 29, 2007 03:54 AM
deathrunner
Aug 14, 2007 05:53 AM
