Budbuilt Transfercase Crossmember Interference?
Old Aug 13, 2007 | 10:54 AM
deathrunner's Avatar
So, I'm finally installing my Budbuilt crossmember. Pretty straightforward install.
I get the main bolts started to hold the crossmember in place while I attempt to align the transfer/tranny mount to the crossmember. I simply coudln't align it. When I investigated, it became obvious that the crossmember was hitting the cover for the CV shaft. I removed this cover and all went into place.
Is this a common thing? Is it a normal part of the install to remove this shield? I figure teh new crossmember will do a much better job of protecting that part anyway.
Can I leave it off and call it good or should I cut down the shield to fit?
Old Aug 13, 2007 | 12:54 PM
Volcom's Avatar
Remove the shield, the budbuilt will protect the CV just fine.
Old Aug 13, 2007 | 01:46 PM
tc's Avatar
tc
Had the same issue - removed the shield, no problems.
Old Aug 13, 2007 | 02:02 PM
rocket's Avatar
Removing that shield and tossing it the trash was the first thing i did. No need for it.
Old Aug 13, 2007 | 02:48 PM
BigBluePile's Avatar
Ditto
Old Aug 13, 2007 | 09:46 PM
Good to know. If I ever make a robot, it will make an excellent cod piece.
Old Aug 14, 2007 | 05:53 AM
amgraham's Avatar
Yeah, I left that shield off too and have wheeled pretty hard for a year and never hit the CV.
1uzRunner
63
Nov 10, 2018 03:58 PM
shooter86314
Jan 7, 2016 07:05 AM
voiddweller
Oct 2, 2015 07:47 AM
90YotaPU
Sep 21, 2015 11:59 PM
yoterr
Sep 15, 2015 06:26 AM
