Sponsored by: CARiD
87 Toyota pickup radiator question
Old Jan 18, 2011 | 07:00 PM
tooleman's Avatar
I have searched and could not find the answer. I am working on a 87 Toyota truck rebuild from the ground up. I have put a 3" body lift on it. The lift kit is a home made kit from 3"x3"x3" harden steel blocks. So my questions are as follows
1. Will the lift affect how the fan cools the radiator.
2. The radiator is from a 2 wd
will cause me problems.
Again if I missed this on the search sorry. The main purpose of this truck is hunting and driving in bad weather and very little extreme off driving.
Old Jan 18, 2011 | 07:06 PM
RogueYota's Avatar
I dont think 3" would affect it too bad but if its in your budget I'd get an electric fan just to be safe.
Old Jan 18, 2011 | 07:11 PM
blakefogt's Avatar
I don't think this is the right place to post a tech question. try here.
https://www.yotatech.com/forums/f116/
Old Jan 19, 2011 | 08:11 AM
peow130's Avatar
You need to also lower the radiator about 3 inches..
When the engine torques it'll smash your fan blade into your radiator.
Or, the alternative is to get a drivetrain lift and smooth out under your body for more ground clearance.
Old Jan 19, 2011 | 08:23 AM
blake.nemitz's Avatar
yea get some 4 inch strips of steel and drill some holes to relocate the radiator 3 inches down
Old Jan 19, 2011 | 08:29 AM
xxxtreme22r's Avatar
yup, there is not 3" between the shroud and the fan. Rad will have to be lowered.
Old Jan 19, 2011 | 08:54 AM
or scrap the mech fan aand go electric like stated above, common sense solutions here not rocket science :-)
Old Jan 19, 2011 | 02:14 PM
tooleman's Avatar
With all the comments about going to electric what are some specs on said fan should i look for?
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
