86 4 runner not starting
I have a good running 4runner at least till yesterday. Weather is very cold. It has been taking longer to crank over to start. Now today wont start. Has had tune up ignition wise. Will fire off with starter fliud. Just a pop. Any help would be great. I am a tech just not for these trucks.
I have '87 and have been having similar troubles. Mine has 22re motor. In normal weather conditions, it never seems to completely warm up. Now with cold weather, it starts but doesn't want to, wants to die until warms up a bit. With much research I'm looking at my cold start system. I'm just having trouble figuring out the componets of the system on my truck. How is your oil? Fuel in the oil indicates an issue of engine temperature. Can be also caused by thermo stuck open. I'll let ya know if I find out anything else.
yea mine just won't start now. Temp outside around 20f . Its been running great, but weather has been warm. Seems to be fuel issue of some sort. Just don't know alot about these. I need to get it in my shop was just wanting to drive it in not pull it.
Battery is new. It is a fuel issue for sure. Got a manual last night. Going to check to see if fuel pump is working. Possibly replace fuel filter. I was considering the cold start injector might be giving me fits. I love the truck just having some new owner blues.
what about the cold start injector? ignition switch have good contacts? plugs, wires? check those things and check continuity as well...never know where a bad wire is.
Team420
01-12-2021 04:57 PM
