22r Timing problem
Pull valve cover
Roll up to TDC and make sure the cam and crank marks are lined up
Pull distributor and reset per FSM
Download here
http://www.ncttora.com/fsm/1985/1985FSM.pdf
Download here
everything is set right. but timing is still off and theres a lag at around 4000 in second gear and on to third gear. if i put the distributer a teeth off the timing comes better but theres a really bad lag.
GreenLion
06-07-2021 10:49 AM
bigblue82
10
07-06-2015 08:27 AM
thelifeadventure
07-02-2015 03:09 PM
83flatt
07-02-2015 10:30 AM
